[MO] UMI Subframe connectors NEW, $150 firm
Car: 84 z28, 86 irocz
Engine: LS6, 305 TPI
Transmission: TH350, T56
Axle/Gears: 3.73, 4.10
Re: UMI Subframe connectors NEW, $150 firm
for long tube or shorty/stock exhaust system?
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
UMI does make two different styles, I have Long tubes, and want the sfc's with out the little 3rd piece. But I think these may work with long tubes fine. Just I dont think the long tube design sfc's will work with stock exhaust or shorty's with y pipe.
But Im not local anyways.
Car: 89 IROC
From all the ones ive seen from UMI all of the 3rd little piece as you put it that goes on the passenger side are all up to you if you put them in. They are an option for you if you want it as you have to weld them in. A few of us up here have them and we are all the same and I dont think any of us put it in
Ok, The third little piece is for Shortyheaders / Stock exhaust system sfc's. The third piece is separate cause it has a bend in it and is made to clear the exhaust pipe that goes under it. Now for the long tube sfc's There is no third piece, the passenger side is just like the drivers. And will not clear the stock y pipe exhaust setups. I would sugjest welding that piece in on your cars. As of now your drivers side is stronger, and that can still cause some twisting.
Car: 89 IROC
Car: 89 IROC
Too bad I know a guy who would take these if you ship to canada. If you change your mind let me know and ill get you in contact with him as hes not on TGO.
Car: 82 Firebird
Engine: Boosted LSX
Transmission: Built 4L60E
Axle/Gears: 4th Gen 3.42s
Can you post a pic or provide the model number?
