Rod bolts and solid motor mounts 350 305
Old Sep 7, 2009 | 08:15 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
i these for a long time and have no use for them
milodon Rod bolts for a 305 or 350
hardened and high strength bolts 25 bucks
part number 82300
moroso solid motor mounts 25 bucks
part number 62630
let me know
joe
Old Sep 7, 2009 | 08:40 PM
kthxbai's Avatar
Car: 1985 Z28
Axle/Gears: fourth gen 3.42
Re: Rod bolts and solid motor mounts 350 305
you have to get the block mounted morosos to use these motor mounts right?
Old Sep 7, 2009 | 08:43 PM
jerflash's Avatar
to tell ya the truth im not sure...i looked it up on jegs but it does not tell you for sure if you need to or not but i would think the stock block mounts would work
Old Sep 7, 2009 | 09:33 PM
kthxbai's Avatar
Car: 1985 Z28
im swapping an lt1 so i figured i would replace the mounts. if these will work for that then ill probably take them off your hands
Old Sep 8, 2009 | 11:26 AM
jerflash's Avatar
look up the part number see if they fit your car
Old Sep 8, 2009 | 07:26 PM
kthxbai's Avatar
Car: 1985 Z28
i think im going to go the poly route. thanks for the info though.
Old Sep 9, 2009 | 12:20 AM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
The stock mounts don't work with the moroso ones. The through bolts are a different diameter. You need the other moroso pieces to use those.
Old Oct 12, 2009 | 01:25 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
these are also the wrong parts for a third gen all together. you need parts numbers 62610, and 62510 for a thirdgen
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
st.evel07
Aug 13, 2015 06:15 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
