[IN] garage cleanout! must go, and looking for parts in trade(UPDATED) LINK TO PICS!!!!!
#101
Car: 91 Camaro RS/63 Chevy II
Engine: 305 TBI/355" Predator Carbed
Transmission: 5 Spd\T400 w/TBrake
Axle/Gears: Unknown/4.11
Re: garage cleanout! must go, and looking for parts in trade(UPDATED) LINK TO PICS!!!
Do you still have the clutch resevoir with hose to master $20? Is the cap for it solid?
Where in Indiana are you? The cap on my reservoir fell apart this morning.
#103
Car: Trans am
How much for the 91-92 third brake light shipped to 18914? Is brake upgrade sold yet? If not pm me pics and price.
#104
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
any chance you have the oil dipstick TUBE that fit the stock 305/350 block? my tube is loose and wiggles all around.. i haven't pulled hte header off yet to see how it's held int here. but if its damaged and loose, ill need a new dipstick tube. how is it held in anyway? press fit?
#105
Car: 85 trans am
Engine: ls1
Transmission: t-56
Do you still have any parts left. You posted this up a year ago and probably dont have much left. Im interested in the wiring harness.
#108
1 Post
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
#109
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
Do you have any of the oil pressure sender fittings that thread into the top rear of the block? Accel ignition module for 87 TPI, pair of regular hood struts?
#111
1 Post
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
how much 4 the aluminum driveshaft shiped to Lancaster, CA 93535 and is it a 1LE
#115
Car: 1983 Z-28
Engine: 5.7 L
how much for the 3rd break light lens that goes on the spoiler?...and for the manual pedals?...shipped to 90650?...if u still have this items...
#116
do you still have the roller lifters/dog bones/spider (with bolts?)
if so, what kind of condition are the lifters in, and do you know how long it's been since they were running?
also, might you have a PROM for a 730 ecu?
#119
Car: 1983 Z-28
Engine: 5.7 L
#120
Car: 83 z28 camaro
Engine: 5.7L 350 4bbl
Transmission: T5 5-speed
hi how much for the torque arm th350 adapter shipped to v1x1v4 canada?
#121
Car: 84 z clone tear down starting soon
Engine: 383 Stroker
Transmission: T-5 till it explodes
Axle/Gears: 3.42 10 bolt disc till it explodes
any lower shifter boots left?
#122
1 Post
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
yes have a few floor boots left
#123
Looking for a few different parts. Alum Driveshaft, 36mm hollow sway bar, spindles, serp brackets or possibly the older style that uses the serp style on the alternator? Let me know. Can do local pickup. Thanks
#124
Car: 1987 Trans Am ws6
Engine: 305tpi
Axle/Gears: 3.73, posi rear
do you have any 5 speed shifter plates for a 85-92 trans am with power windows?
#125
Car: 1992 Camaro RS
Has the A/C delete sold yet? If not im interested. Thanks
#126
1 Post
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
most of the stuff in this thread is gone for the most part... its an old thread
#127
Car: 87 IROC-Z
Engine: 383 HSR $8D
Hey...I bought a right ground effect off of you last summer(met you in Trafalgar). I need more stuff and was wondering if you could help me out.
I am putting AC back on my car and I need the following pieces...
1) Hard line that goes between AC Condenser and Orifice Tube. Mine the fitting has been damaged and I need to replace it.
2) I need the rubber pieces that hold the condenser on top. The lowers are 1 piece with the radiator...the tops have disappeared over the years.
If you can help me out, I'd appreciate it....
Thanks,
Thanks,
#128
1 Post
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
i think i have the ac lines.. not sure about the rubbers but i might have those too
randy
randy
#129
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
parking lamp for my 86, must be amber, wonderbar, rear view mirror, must be clean!!,gauge lens, center cap for my 15" alum rims( pic in sig)
#130
Car: 88 Camaro IROC-Z Convertible
Transmission: 700R
I need that fron license plate holder. How much to ship to 78572?
#131
Car: 89 Trans AM
Engine: L98 5.7
Transmission: 5speed
do you by chance have a cat for a stock ypipe?
#132
Car: 1987 tpi camaro not sure of motor
Engine: 5.0 tpi
Transmission: 5spd
Axle/Gears: posi track rear end gears unknown
do you still have the ls1 heads by chance and how much shipped to 84097?
#133
Car: 1987 Silver IROC-Z
Engine: 305 V-8 300HP LT1 Cam
Transmission: T-5 5-speed
Are any of the Torque Arm Bracket for a T5 transmission?
Joe
Joe
#136
Car: 1991 Pontiac Firebird Base
Engine: 350 Carb'd and Cammed :)
Transmission: Stock T-5
Axle/Gears: Stock
still have TH350 Torque Arm bracket. How much shipped to 74429. Thanks..
Street Lethal
08-12-2015 11:33 AM
