[CA] Aluminum LS1 Driveshaft
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Aluminum LS1 Driveshaft
If the U-joints are still good, this is an awesome deal.
The ujoints are fine but I would probably replace the back one just as a precaution as it seems to be getting a bit tight. They're fairly cheap and easy.
As far as an upgrade I'll let other people answer that question. People claim aluminum drivesahafts are better bedcause they're lighter and they also offer less vibration. I'm located in Torrance.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
If it does i will take it i live hear in Norwalk and i am gonna replace my tranny soon and i might as well put a aluminum driveshaft in it too
I have 1 person in line if he's not interested its yours. I'm pretty sure it will work with an auto tranny just fine but I'd do a search to make sure.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
yea i did a search right now and it is a direct bolt in just trying to find out to how tight it has to be, or do you know how much to tightend them to
1 Post
Car: 1987 IROC-Z
Transmission: TH350
It will work if you have a 700r4 or a T5.
It reduces some of the high speed vibrations of the stock steel one,, it is stronger, it has a more precise balance, it is significantly lighter, it frees up some power, and it has a higher maximum velocity. The only down side is that it isn't as strong as a $400 chromoly driveshaft.
When i did the swap, I noticed throttle response was a little better due to less rotational mass.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I might get this if he doesn't sell it to the other guy hey racing geek can you please PM if you remember how you installed the driveshaft
school boy
10-22-2015 11:47 AM
Royal_Z
09-30-2015 08:45 PM
91, alum, aluminum, california, camaro, driveline, driveshaft, driveshafts, engines, install, joints, ls1, sale, stock
