[NY] Rotating assembly,cam kit etc.
All this only has 3000 miles on it
Used rotating assembly includes
Scat cast 3.48 stroke crank
Pro tru pt003hs standard size pistons 4.000 bore
Scat 5.7 forged rods with 7/16 cap screws
Summit stock replacement balancer
All balanced by competent machine shop
Pistons and crank have minor scratches on them not a problem at all
Looking to get 550 for that stuff
Cam kit
Trick flow roller cam 246/254@ .050 .558 lift 112 lsa
Crane hydraulic roller retrofit lifters , Springs, retainers, keepers, spring locaters.
Also have 7.250 pushrods which may work depending on your engine
Looking to get 500 for that stuff
Holley street dominator manifold 50 bucks
Proform race carb 750 cfm has a holley float bowl on primary side.
1/8 inch holes in butterflys to get some air in at idle.
lookin to get 250 for that.
Cam kit
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Rotating assembly,cam kit etc.
ambainb
Apr 25, 2016 09:21 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Mickeyruder
Sep 2, 2015 02:45 PM
