[AL] WTT Holley Stealth Ram setup!!!! Look Inside
Old Nov 22, 2009 | 09:34 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I want to put my entire Holley stealth ram setup on the table to see what I can get.
Here is what you Get.
Holley Stealth Ram
Fuel rails
Venom 24 lb injectors
TPI distributor
MSD Coil
All sensors
Wiring Harness
Moates Emulator, with chip burner (You can tune with laptop real time)
TPI Fuel pump (if I haven't sold it by then)
Here is what I want.
A 100% complete bad *** carb setup.
I have a fully modded 383, cammed, and automatic. Base your setups on that.
I run a 255lph pump so I will need a 3 port regulator. Best setup wins.
I need an:
Intake
Carb
Distributor
Throttle brackets
3 port regulator
MSD for limiter
Air cleaner
Nicer the better.
Will add pictures later
Call me if interested. I am not desperate so, trying to pawn me junk wont do you any good.
Cale 251-209-1518
Old Nov 22, 2009 | 09:51 AM
petko0's Avatar
Engine: built 350 TPI
Re: WTT Holley Stealth Ram setup!!!! Look Inside
how much cash would you want for the whole stealth ram setup?
Old Nov 22, 2009 | 03:21 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
For the HSR, ECM, harness, all sensors, tuning emulator everything, probably around $1k maybe a tad more
Old Nov 22, 2009 | 03:50 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Pics Updated
Old Nov 22, 2009 | 07:46 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Why have you decided to ditch the HSR and go carb?
-- Joe
Old Nov 22, 2009 | 08:24 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
-- Joe
I agree, I have a pretty nice carb setup... all of it is new with less then 100 miles on it, but i was considering going FI... I just dont know if I am ready yet. Plus, it makes me wonder why someone would want to go from FI to carb, are you having trouble tuning it? Is it not running right? Whats the deal?
I have a Super Victor intake, blueprinted holley 750dp, CSR billet throttle bracket, MSD streetfire distributor, MSD superconductor wires, msd 6a mallory 3 port regulator, mallory 140gph (530lph) pump and prefilter... 2" drop base air cleaner setup from a 67 corvette repro part... setup fits under my stock hood.
Damn, I just listed about $2k worth of parts...I dont think I wanna trade unless you can convince me otherwise.
Old Nov 23, 2009 | 07:24 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I'm not much for tuning electronically. It runs fine but I think it could be much better. I might sell the emulator and go to mega squirt.
I love a clean engine bay, hence carb setup.
I don't have to convince you for nothing, I am not desperate, so you need to convince me. I am interested to see what people offer. If you want to talk about what things are worth Its almost $3000 for a stealth ram, wiring, ECM, and all sensors, distributor etc. And I am added an emulator/ Prom Burner/ Data logger.
If people want to hear it run let me know. The exhaust is loud but you should get the idea.
Old Nov 27, 2009 | 07:54 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Still looking for a setup. Call me if you have a trade.
Cale
Old Dec 5, 2009 | 12:45 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Top
Hotrodboba400
Dec 10, 2019 07:07 PM
Stangski09
Nov 14, 2015 01:27 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Slush92RS
Sep 2, 2015 08:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
