rear, flywheel, disc brake master cylinder, motor
Car: 1986 Iroc Camaro
Engine: 383
Axle/Gears: 373 gears
-i got a disc brake rear end with the rear sway bar $200
-i have an aluminum flywheel for a t56 to go behind a small block (new) $100
-i also got a brake booster with the master cylinder and prop valve for a disc/disc setup $75
-lastly i have a freshly machined 350 tourque plate honed to a 355. the crank has been polished and the block and crank are completely ready to go. it comes with the original rods and pistons but will need new pistons but the rods are fine. it has the big valve 882 heads that just need to be cleaned up. it comes with a new remanufactured standard intake that has been milled for increased flow. i also have an oil pan for the motor and an old distributor. this motor is orginally out of a 1968 camaro. for everything i am looking for $425
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: rear, flywheel, disc brake master cylinder, motor
Is this flywheel for a 1 pc or 2 pc RMS??? interested, got any pics???
Engine: 383
Engine: 383
Car: 1985 Monte Carlo SS
Engine: 5.7L
Transmission: WC T-5
Axle/Gears: 3.73:1
Engine: 383
the number is F 091059. i know its for a two peice rear main because i have the engine that it was going to be used with and it is a two peice rear main engine. the center hole is right at 2.5".
Engine: 383
Engine: 5.7L
Axle/Gears: 3.73:1
What's the overall thickness of the flywheel (just to compare with the stock T56 flywheel I have)? Do you have any other pics from a different angle?
How much would shipping through USPS be to Ontario, Canada?
Engine: 383
sorry for the delay ive been busy. the overall thickness is right at an inch and including the external balance its dead on an inch. usps to you would be $35. and heres some pics:
Engine: 5.7L
Axle/Gears: 3.73:1
Thanks for the pics, but I'll have to pass - this looks like a standard external balance flywheel for a 2pc rear main motor.
A T56 flywheel would be around 1.75" thick, and I need one that's for an internal balance motor.
Car: 89 Vert Camaro
Engine: 3.8SFI Turbo
Transmission: 200R4
What year did the rear come out of? and what is the ratio?
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
