327 sbc AFR heads 11 second motor complete drop in. NJ
Old Jan 7, 2010 | 09:37 PM
zddp8868's Avatar
Car: 1968 chevelle
serious inquires ONLY.
327 small block chevy .030 over out of my chevelle
BORED TO 331.6 CI. (30 THOUSANDTHS OVER)
ENGINE DECKED, BORED AND HONED W/ PLATES, BALANCED ROTATING ASSEMBLY. SHORTBLOCK WAS DONE BY TIM ZEPP @ TIM ZEPP ENGINES
http://timzeppengines.com/
10.57:1 COMPRESSION, RUNS ON 91 OCTANE.
SPEED-PRO FORGED DOME PISTONS PN: L2166NF30
GM POWDERED METAL I-BEAM RODS 5.7
FACTORY FORGED STEEL CRANK (CUT)
CAMSHAFT:
SOLID FLAT TAPPET
CUSTOM UDHAROLD DESIGN GROUND BY LUNATI (249/255 278/284 .540/.550 106) i have the cam card. the cam was ground on a P55 core.
1 piece hardened comp cams .100 over pushrods
crower EDM hole solid lifters
CYLINDER HEADS:
AFR 195CC ELIMINATORS http://www.airflowresearch.com/index.php?cPath=24_29
1.5 RATIO COMP CAMS ALUMINUM ROLLER ROCKERS
EDELBROCK PERFORMER RPM AIR-GAP INTAKE MANIFOLD 7501
went high 11s in my full weight chevelle. motor makes 465 horsepower.
the bottom end has about 3500 miles on it total since it was built. the heads have about 500 miles on them and the cam has about 200 miles on it. can hear it run. i know this engine up and down. timmy built the shortblock, i changed the heads and cam later on.
you get the motor from intake to pan, balancer to flexplate.
I AM EVEN INCLUDING THE POWERMASTER 100 AMP ALTERNATOR, ALL PULLEYS AND BRACKETS, WATER PUMP, DISTRIBUTOR AND WIRES. i will throw in the ignition box and ignition coil for 100 bucks too. the headers are for sale as well, they are hooker 2451s. they fit A bodys.
the only thing i am not including is the carburetor. bolt a carb on and go 11s.
any other questions let me know, email me 24/7 for my phone number.
$3900 complete engine with all accessories. only thing i'm not giving you is the carburetor. located in south jersey.
350 355 383 327 302 305 400 406
Old Jan 7, 2010 | 09:43 PM
zddp8868's Avatar
Car: 1968 chevelle
Re: 327 sbc AFR heads 11 second motor complete drop in. NJ
http://southjersey.craigslist.org/pts/1542484111.html
includes fuel pump as well. im even including the belts, distributor, everything!
Old Apr 20, 2010 | 04:15 PM
bg383's Avatar
will you sell the heads seperately, and what size is the combustion chamber on the heads?
Old Apr 20, 2010 | 06:15 PM
zddp8868's Avatar
Car: 1968 chevelle
the heads are sold. the shortblock is now for sale for $1200 obo
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
89mulletbird
Aug 12, 2015 07:08 PM
L98GTA87
Aug 11, 2015 06:55 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
