[FL] 355SBC; full roller/alum heads, Complete!
Car: projects.......
355ci hot street/strip type combo
- 200cc Pro Topline aluminum angle plug heads, Manley street master valves, Comp dual roller springs, Comp moly retainers/locks, Manley guide plates, Manley 1-piece .080 moly pushrods, Comp roller rockers, ARP head bolts
- billet hyd roller, 242/248 @ .050, .567/.585, 110ls
- Crane hi energy OE type hyd roller lifters
- billet true double roller 9-keyway timing set
- Weiand Team-G (iirc 7730)
- 750 Holley vac 2nd
- 4340 h-beam rods, bushed/floated(ohio)
- hyper flat-tops, zero deck, 10.989:1 compression, moly rings
- Late-model 1-piece seal block(2-bolt)fully machined/prepped
- fully prepped std/std Gm cast crank; chamfered/deburr'd
- bolt-in windage tray
- stock type pan
- Fluidamper - streetdamper
- HEI dizzy, gutted for MSD ignition(can included perf module), polished housing, low mile MSD cap/rotor, remote coil set-up, Accel 9.5mm wires
Motor turned 7200 in low gear, made peak power around 6800. Less than 15k miles on all parts; roller cam, rods, rings/bearings less than 10k, less than 1k on Crane lifters. Currently top end removed and pan loose for inspection, have new gaskets to go with it, can be bought as pieces or re-assembled.
It is in great shape, I would run it again in a minute if I had a use for it. Treated me very well as my hot rod through college. Been keeping the ol' friend around, but I have no use for it, and if it sold I could buy some things I could use.
Hoping for quick sale to pick-up BBC short-block, asking $2650 with h-beams or $2500 w/ GM "powder forged" rods, floated w/ good bolts; complete, carb to oil-pan, including dizzy, plugs, & wires. - I have well over that in the top end alone.
Thanks for looking,
- Jp
preffer local pick-up/meet; can "palletize" and fork-lift from shop in Naples FL 34109, but buyer would responsible for all shipping arrangements/costs
- stock type pan
Thanks for looking,
- Jp
Terrell351
Jun 13, 2021 01:13 PM
ambainb
Apr 25, 2016 09:21 PM
