[MA] 6.0L LS Engine F/S
Old Feb 19, 2010 | 07:48 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
6.0L LS Engine F/S
hey i have a complete 6.0 Liter LS motor out of a silverado, it is completely dissassembled right now and will need to be put back together.i was told it has around 80k on it and includes the truck intake and an LS1 intake, has iron heads. Needs new cam bearings, crank bearings and rod bearings installed before re-assembly.
Looking for 600 bucks cash
LOCAL PICK-UP ONLY --PLEASE DO NOT ASK IF ILL SHIP IT BECAUSE I WONT--
Old Feb 19, 2010 | 08:11 AM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Re: 6.0L LS Engine F/S
location?? is it a lq9 or lq4?
Old Feb 19, 2010 | 10:06 AM
located in Massachusetts, i thought i selected that, anyway its an LQ4.
Old Feb 19, 2010 | 03:00 PM
Jeromey Cummins's Avatar
Hey, will you ship it? LOL! Just kidden..... good luck! To bad you werent closer, id come get that bad boy!
Old Feb 19, 2010 | 10:17 PM
iroc1793's Avatar
Car: 1987 Camaro Iroc-z
Engine: 305 tpi
Transmission: t5
where in mass are you excatly?
thanks
Old Feb 20, 2010 | 10:02 AM
Fitchburg area... not too far from Turners Falls
Old Feb 20, 2010 | 11:03 AM
iroc1793's Avatar
Engine: 305 tpi
Transmission: t5
you said its complete, does that mean it has accs and all sensors? maybe a wiring harness? and i think your about 45 mins to and hour away not bad.
Old Feb 22, 2010 | 08:21 AM
So i talked to my buddy who sold it to me this weekend and he told (btw i bought this engine on impulse and only saw the block on the stand, and he told me what came with it, so bear with me here...) me that there is no wiring harness or ecm, the camshaft bearings and crank bearing went bad from gas getting into the oil so the rest of the engine is fine. it doesnt include any accessories except the powering steering pump and bracket, however, if you run the LS1 intake, it will need the vette or F-body brackets since the LS1 intake TB is lower than the Truck TB. im lowering price and holding @ 475.
Old Feb 23, 2010 | 09:59 AM
400 FIRM, need gone asap!
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
