[GA] Multiple TPI Setups
Car: 1991 Camaro Z28
Multiple TPI Setups
I'm looking to sell multiple TPI setups. Awhile back I would powdercoat TPI units and sell them on Ebay. Then college came around and took up my time, and now I simply have them sitting around the garage.
I'm guessing it's 6-7 complete units with multiple spare parts. I'd like $125 per unit or if someone is interested in everything (possibly to powdercoat them as I once did) I can work something out for buying everything in bulk.
If someone is interested in buying the bulk, I can also supply you with the metal ***** I used to knock the dents out of the runners.
Send me an e-mail at matthew.moorman@robins.af.mil if you have some interest. I'll try to get some pictures up tonight.
Car: 1989 IROC
Re: Multiple TPI Setups
Here is the 89 like I need. The fins are not as long and only the two intake holes in the front no triangle cut out between them.
TPI1.doc
TPI1.doc
Car: 1986 Z28 Iroc
Hey man,
Would this be everything I need to swap my car from a carb to TPI? I really want to swap it out to be a TPI car, it's got a 350 that was swapped in, and is still running the CC'd carb. It has problems, which I've narrowed mostly down to fuel delivery. I want to do the swap for drivability as well, since this car is my dd.
No, I don't have the wiring harness or many of the sensors required to perform a full swap. You'll want to look for a full TPI setup with harness/ECM.
Car: 1989 IROC
Here is a link for the different TPI parts by year.
http://hotrodlane.cc/PDFFILES/TPIStory.pdf
I could not get pictures to load.
Billy,
Sorry for the late response. I do have a newer model plenum. 1 of 12 actually. Let me get an idea of how much they go for and I'll send you a price. This one appears to have been polished some on the top. Not sure if that's a bad thing for you or not though.
Car: 1989 IROC
Great thanks also look to see if you have a throttle body for an 89. I would like a plenum and throttle body please. Top being polished won't hurt, just looking to use them for some testing.
FUNIROC,
It does not appear that I have a later model throttle body based on the .pdf above. I'm still looking through my garage to see if I have any other throttle bodies buried underneath anything.
Car: 1989 IROC
Ok, shoot me a price shipped for the plenum then. Just let me know if you come across a 89 throttle body.
My ship to is:
Woodstock, GA 30189
Billy/FUNIROC
My ship to is:
Woodstock, GA 30189
Billy/FUNIROC
Sanjay
Aug 12, 2015 03:41 PM
