[IA] JET Perfomance Stage 1 Chip 305TBI auto camaro/firebird
Car: 89 TTA
For stock or mildly modified engines
Fuel and timing curves optimized for use with low octane
Fuel burned at peak efficiency for improved performance and mileage
Midgrade octane is recommended for even better gains
75.00 + 4.95 shipping
Car: 1987 iroc
Engine: 391 stroker
Transmission: th350
Axle/Gears: 10bolt/4:10
Re: JET Perfomance Stage 1 Chip 305TBI auto camaro/firebird
hi i am very interested in the chip and was wndering if the stage 1 prom had vats??? i recently swapped my 84Z to tbi but the car the harness and ecm came out of had vats so i kind of ran into a little snag.... i was able to get the car running by using a s10 4.3 vinz ecm and by-passing the starter enable relay, and it runs good but i knw its not rite and i was told the ecm wasnt the problem but actualy the prom had the vats in it, so plz let me knw
Car: 89 TTA
the prom number is jet # 18905
http://www.jegs.com/p/JET/JET-Powert...48456/10002/-1
Im pretty sure it has vats enabled.
you can bypass your vats using a resistor. Locate the vats wire coming form under the column white wire with orange sleeve i belive,cut it and solder or crimp a resistor in place,use a volt/ohm meter on your ket to find the correct resistance.
Drone358
12-10-2015 08:16 PM
