[CA] Another megasquirt 2 w/ harness for sale
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Up for grabs is the latest version of megasquirt 2, tested and definitely functional. This one I am selling for a friend that has gone a different way.
Will come with the pigtail and a good stretch of wire that plugs into the megasquirt 2, You will need to wire in every pigtail but every wire is labeled very clearly.
This megasquirt 2 will also include the stimulator, this is a device you plug into your ms2 box and it simulates your ms2 on an engine so you can make sure everything is working correctly. mostly used for assembly, but its here just in case.
If you know megasquirt, you know how cheap they are to aquire. Consider that along with a ready to build engine harness, and stimulator let me know what its honestly worth to you
2, 20, boards, californai, california, cheap, egasquirt, for, harness, mega, megasquert, megasquirt, sale, squirt, stimulator, wire
