Stealth Ram bundle MSD DISTRIB used
Old Jun 3, 2010 | 05:38 PM
IROC4U's Avatar
Car: 87 IROC
Engine: GM 350 soon to be supercharged
Transmission: tko 600
Axle/Gears: 3:73
Stealth Rame Upper lower intake holley 58 mm throttle body fuel rails 26lb accel injecters adj fuel reg tps IAC and Air temp sensor CTS and KN air filter (the stock) throttle and transmission bracket included 700.00 Shipped less then 400 miles
Msd Distributer less then 400 miles 150.00 Shipped
also have iroc wheels good shape need to be cleaned up 175.00 with new center caps black with silver lettering
32lb accel injecters looking for 145.00 shipped less then 100 miles on them
a ton of other parts
charcoal seats front back
4th gen z28 wheels
1 iroc hood with louvers
1 reg hood
one 84 z28 hood
rear hatch for 87 iroc
700r4 goodwrench trans milage unknow needs lock up switch
v6 transmission 92 camaro worked good went through all gears
rear end with no brake lines drum brakes (no drums will go for cheap)
cold start valve for 87 iroc 305 tpi
4 ecms from 85-92 irocs make offers
Old Jun 7, 2010 | 04:26 PM
boozeslinger79's Avatar
Want a title? Post!
Re: Stealth Ram bundle MSD DISTRIB used
wondering what the part num is on the distributor. thanks
Old Jun 7, 2010 | 04:52 PM
IROC4U's Avatar
Car: 87 IROC
Axle/Gears: 3:73
http://www.summitracing.com/parts/MSD-8366/
Old Jun 7, 2010 | 04:58 PM
Want a title? Post!
interested, do you have the coil availiable and what year car was it off of? thanks again
Old Jun 7, 2010 | 05:03 PM
Twin_Turbo's Avatar
I'm interested in the dizzy too and will take it if boozeslinger79 doesn't want it.
Old Jun 7, 2010 | 05:12 PM
Want a title? Post!
pm sent
Old Jun 14, 2010 | 02:56 AM
camarostylin's Avatar
is that a COMPLETE stealth ram setup with harness/ecu and everything? and if so, is it still available?
Old Jun 14, 2010 | 05:28 AM
Twin_Turbo's Avatar
boozeslinger, did you take it or not?
Old Jun 14, 2010 | 01:43 PM
IROC4U's Avatar
Car: 87 IROC
Axle/Gears: 3:73
he took the distributer and the bundle is only whats included no ecm wiring
Old Jun 15, 2010 | 01:35 AM
ogg__666's Avatar
Car: 1988 iroc-z28
Engine: 305 tbi
Transmission: new 700r4
Axle/Gears: um 2.77 i think
how much for a tpi emc for a 305 4 speed od ? and shiped to V0N 2P0 ?
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
