parting out 1987 iroc-z 5.7tpi
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Re: parting out 1987 iroc-z 5.7tpi
Interested in the upper radiator fan shroud piece but only if it has no breaks or cracks.
Also need the lower radiator rubber isolator/insulators (the rubber pieces that the radiator/ac condensor are sitting on top of)
If all or some is good, how much shipped to NY 11735?
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
2011 Norwood Gathering
ThirdGen Camaro Rep
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Interested in the 2 brackets that attach the rear bumper cover, and the 2 side brackets that attach the chin spoiler to the front fenders.
shipped to 48083
shipped to 48083
Car: 91 Z
Engine: Somethin Nice!!
im located in Mass...how much for the ENTIRE motor, accessories and harness? how many miles? any leaks? hows it run?
also condition on the rear end? posi? disk brakes?
the rear is a 3.27 disk posi for $150.
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
How much for the computer and if the wiring harness is uncut, how much for that too? Can you get me pics of the numbers on the computer to verify it is what it should be?
give me another day to get the stuff off the car and i willpost pics.
i will have the wiring taken out in the next couple days and i will get the #'s off the computer and will post pics. $65 shipped for computer or $170 shipped for harness and computer
serv.# 1227165
869461 ?611510818
16059461
if that helps. it is a 5.7 and has the 8 as the code on the vin.
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
