[NH] Parting out low mi 305 TPI
Car: 1987 IROC-Z
Engine: 305 tpi
Transmission: t5
Axle/Gears: 10-bolt w/ Richmond 3.42's
1987 IROC-Z, 305 TPI 5 speed w/ only 71k miles. Parting out the entire engine. Prices listed below, but will take offers. I just want to see everything gone.
Wiring harness (no cut wires) $100
ECM $55
MAF Sensor (was not throwing ANY SES codes) $175
K&N Filters $20 for the pair
dual snorkel air intake $60
Firewall Sensors $45
Intake base $60
Plenum $60
Runners $35
Throttle body $40
Distributor $35
Miscellaneous parts - $
ECM $55
Intake base $60
Plenum $60
Runners $35
Throttle body $40
Distributor $35
Car: '90 IROC Convertible
Engine: 305 TPI LB9
Axle/Gears: 3.23 Disc Brake LSD
Re: Parting out low mi 305 TPI
Is the intake base for full 90 degree bolts or is it for the heads with the canted two center bolts?
Engine: 305 TPI LB9
No, not for the alternator bracket.
The center two holes on each side of the intake typically on the '87 and newer heads/intakes are canted slightly, not being at the same 90 degree angle as the front two and rear two bolt holes on each side of the intake. Some folks call the newer style ('87 and newer) center bolt heads but that is not totally correct as they make some heads like what I have with center bolt valve covers but all the intake bolt holes are all at a true 90 degrees. The heads I have are the L98 aluminum heads.
Since you have an '86 305, there is a possibility that your intake has all the bolt holes to bolt the intake down to the heads at the same angle. The specific GM part number I am looking for is 14081005 (TPI intake number).
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Sanjay
Aug 12, 2015 03:41 PM
