[NJ] 355 TPI ENGINE $2500
Old Jun 20, 2010 | 09:39 AM
nj85z28's Avatar
Car: 1986 Monte Carlo SS
Engine: TPI
Transmission: Level 10 700r4
Engine has about 2500 miles on it.
355 sbc
3970010 casting
4.030 bore
honed with torque plate
line honed
deck milled .020
durabond cam bearings
new freeze plugs
screw in oil galley plugs
blueprinted and assembled
gm crank cut .010 and polished
trw forged flat top pistons
trw moly ring set
scat I beam connecting rods w/ arp bolts
king rod and main bearings
pioneer 153 tooth flex plate
pioneer 6" balancer
trw pins pressed on and rotating assembly balanced
howards hydraulic roller cam
speed pro hydraulic roller linked lifters
sa double roller timing set
melling HV oil pump and pickup
comp prod cam button and retainer plate
fel pro gaskets and seals
Heads-
882 casting
1.94 intake valves 1.5 exhaust
bronze guides
pocket ported
surface milled
machined for pc seals
assembed with new springs and retainers
comp prod. valve spring and retainer set
comp cams push rods
elgin 1.5 ratio roller tip rocker arm set
cometic MLS head gaskets
VTO valve seals
Also has a new 88 Vette distributor
EGR AIR VSS Deleted
Asking $2500 obo for the engine....
comes with all the paperwork from JSPerformance who built it.
Engine comes with TPI computer, MAF, Harness and would be ready to drop in your car and go.
Old Aug 9, 2010 | 06:24 PM
nj85z28's Avatar
Engine: TPI
Re: 355 TPI ENGINE $2500
BUMP
PRICE DROP
$2000 obo!!!!!
The Camshaft is
Howards 110245
Valve Lift- .504/.504
Duration 280/292
gross lift- .336/.336
Degree @ .050 222/230
Old Aug 9, 2010 | 11:20 PM
IROC-Z_Racing's Avatar
Car: 89 IROC-Z28
Engine: LS1 "ASA"
Is this motor an original 355 block, rebuilt with the above mentioned parts, and since the rebuild it has 2500 miles on it? Also was this attached to an automatic or a manual tranny?
Old Aug 10, 2010 | 04:29 AM
nj85z28's Avatar
Engine: TPI
a 355 is more or less a 350 block bored .030 over.
For my build, a 350 was machined .030 over and assembled, the heads were machined and assembled and the engine was put together and installed in my 86 Monte Carlo SS.
The car was rotting around itself so shortly after the engine was put in I decided to pull it out and put it into an IROC-Z. Being out of work that plan fell through and now I've decided to part with it.
So since original assembly there are 2500 miles on the engine.
and I ran a fully built 700r4, but this engine will also bolt to a t5. I know people with similarly built 355's that use the World Class T5
Old Aug 10, 2010 | 09:22 AM
Car: 89 IROC-Z28
Engine: LS1 "ASA"
Yeah, I've got the stock T5 in my 89 IROC. Do I need to change the flexplate or change something down there to adapt to a manual transmission or will it, like you said, bolt right up, no changes? I've never done an engine swap before, just trying to get my ducks in a row before I do anything. And you wouldn't happen to have any power numbers on this engine would you, HP and TQ? Thanks for the info.
Old Aug 10, 2010 | 04:02 PM
nj85z28's Avatar
Engine: TPI
you would use the flexplate and stuff off your current motor. otherwise no changes. same mounts, bolt pattern, etc
and if your running tpi already its even easier. just plug and play.
never had the engine dynoed.
Old Aug 10, 2010 | 04:53 PM
Car: 89 IROC-Z28
Engine: LS1 "ASA"
Nope, I've got the so totally awesome LO3 TBI!!!
But, since you're also including the harness and computer that run this motor, then it will still be easy. All I have to do is pull out my old harness and run the new one. I'll get back to you here in the near future. Got to do some planning and thinking first. Thanks for your help.
Old Aug 10, 2010 | 05:48 PM
nj85z28's Avatar
Engine: TPI
No problem!
Old Aug 27, 2010 | 10:56 AM
Car: 89 IROC-Z28
Engine: LS1 "ASA"
I haven't forgotten about you. Just gotta get the money in line. I am really wanting to get this motor, but I'll need to get the tools, rebuild my tranny, my stock 3.08 rear should work for now, etc... I'll keep you informed.
Old Sep 16, 2010 | 02:52 PM
PTS's Avatar
PTS
Car: 89 Vert Camaro
Engine: 3.8SFI Turbo
Transmission: 200R4
Did you sell this motor?
Old Sep 22, 2010 | 03:19 PM
Fermin91rs305's Avatar
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
im looking to buy this engine from you is it still for sale... Please email me asap if possible at carranzafermin@aol.com
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
