[CA] 383 with 475hp and 485ftlb
Car: 91 CAMARO RS v6 78 c10 350
Engine: 3.1
Transmission: 5 SPEED
Axle/Gears: stock
i have a 383 with 475hp and 485ftlb. i build engines on the side. and its has all new parts. i have a long list of everything in it and dyno printout.
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
Re: 383 with 475hp and 485ftlb
if there is no price listed in the classified....then it's free?
I'll take it...lol
I'll take it...lol
Engine: 3.1
Axle/Gears: stock
6000.00 i can also run it for u at my house.
383 stroker with 485 ft lb tq and 475 hp. ON 91 PUMP GAS I ONLY TAKE CASH OR PAYPAL!!!
I HAVE DYNO PAPERS ON HAND AND CAN ALSO RUN THE ENGINE WHEN YOU COME AND LOOK AT IT
4 BOLT MAIN BLOCK 2PC REAR MAIN SEAL
BORED .030 AND HONED AND DECKED
BRASS FREEZE PLUGS AND OIL GALLERY KIT INTALLED
BLOCK PAINTED 3 COATS OF HIGHT TEMP PAINT
NEW EAGLE CAST STEEL CRANK 3.750 STROKE
NEW EAGLE I-BEAM CONNECTING RODS WITH ARP BOLTS AND BUSHED PINS
SPEED PRO HYPEREUTECTIC COATED SKIRT PISTONS
CLEVITE 77 MAN AND ROD BEARINGS
PERFECT CIRCLE PISTON RINGS
LUNATI FLAT TAPPED CAM
16- LUNATI MECHANICAL LIFTERS
16- CHROMEMOLY HEAT-TREATED PUSH RODS
EDELBROCK E-TECH CYLINDER HEADS 200CC INTAKE RUNNER AND 2.020 INTAKE VALVE AND 1.600 EXHAUST VALVE
3 ANGLE VALVE SEAT
VALVE SPRINGS AND RETAINERS TO MATCH CAM
EDELBROCK AIR GAP RPM INTAKE
750 CFM EDELBROCK CARB
CHROME OIL PAN
CHROME TIMING COVER
CHROME DIPSTICK WITH TUBE
CHROME THERMOSTAT HOUSING
CHROME TUFF STUFF SHORT HIGH VOLUME WATERPUMP
EDELBROCK CHROME VALVE COVERS
FEL-PRO GASKETS
FLEX PLATE
AND MORE
I CAN ALSO RUN THE ENGINE IF YOU WOULD LIKE ME TO ALSO
3 ANGLE VALVE SEAT
CHROME OIL PAN
CHROME TIMING COVER
FEL-PRO GASKETS
FLEX PLATE
AND MORE
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
anything forged??? Specs on cam please. Do you have the dyno sheets available
Engine: 3.1
Axle/Gears: stock
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
Car: 1988 Camaro
Engine: 383 Stroker
why would someone buy this if they don't know the cam specs????
LT1Formula
Oct 8, 2015 08:34 PM
