[NJ] TPI Engine Stuff for sale!
Car: Check The Sig
I have a bunch of stuff I need to sell!!
1) moddified LB9 heads. They have a 3 angle valve job, with a larger 1.94 intake valve. Had them on the car for 2k miles on it before I decided to go LS1. Comes with polished centerbolt valve covers as well. Looking for $150
3) Full TPI set up with a slight polished. Plenum has been ported and gasket matched. EGR walls were ground down as well. Runners are also polished, but not touched, same goes for base plate. Fuel rails come with Holley fuel pressure regulator and a fixed fuel pressure guage. Still has the 9th injector.
Looking for $300 for the whole thing, will part out.
4) Full TPI harness. Only thing cut was one of the wires to the starter. This is the harness that connects to the ECM. $75 for the harness
5) TPI ECM with custom PROM to work with the heads and cam. PROM alone is worth $200, so PROM with ECM together $200.
PM or email me at BigAls939C1@yahoo.com
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
Re: TPI Engine Stuff for sale!
I cant remember if I contacted u bfore if I did I apologize. What Im looking for is the EGR setup.
Car: 1984 Chevy K5 Blazer
Engine: SD TPI 350 w/FIC Bosch IIIs
Transmission: 700R4 4X4
Axle/Gears: 3.08 front and rear w/ 33" AT tires
Ill take the heads off your hands!!! Shipping to 30907???
$350 for heads plus shipping and maybe extra when I get them for being a great sport!!!
Maybe we can talk about the heads, cam and computer... I am in need of heads... stock Camaro Eprom and computer with 22lbs flow matched injectors are what I have.
Call me!!! 706 333 4413
I am in Augusta GA
I am in Augusta GA
Car: 1989 Iroc Camaro
Engine: Stock 350 TPI
did you ever sell the headers and y pipe. did you put a bung of the o2 sensor in headers. can you ship to sumner iowa 50674 if you still have them. will you go down on price
Engine: L98 TPI 5.7L 350
Transmission: 700R4 Automatic
ok. do u have the 9th injector, or maf? how much to ship to 92585. thanks.
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
