[NJ] Moates TUNING stuff! i also do tunes
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
1.) moates burn 2 chip burner
USB Chip Programmer works with the AT29C256, 27SF512, and AM29F040 chips. Self-powered from the USB port, so no power adapter is needed! Burner can also be used to read stock GM memcals using the HDR1 adapter. While it will only program the three types of chips listed, please note that those three chips can be used as drop-in replacements for most EFI applications. Comes with stand-alone chip programming software (available for download). Also compatible with TunerPro RT. Will read most stock-style chips (2732A, 27C128/256/512/etc).
2.) moates HDR1 chip adapter
Use this adapter to read the 'stock' binary from your TPI-style Memcal. Plugs into your 'stock' P4-style Memcals. Allows you to download your original 'factory' chip contents directly using a chip programmer/reader like the BURN1, BURN2 or APU1. Very durable, and designed for repeated use.
3.) i also have 1 blank chip that is used to store the "tune" on, and plugs into the G1 chip adapter thats sold by craig moates. this blank chip is rated for thousands of erases before it needs to be replaced.
Im selling 85% of what you need to tune your own engine, all u need is the G1 adapter thats 35$ and you could be burning your own chips. I can also do tuning for engine mods like heads,cam,intake, injectors etc i can turn off VATS or cold start deletes.
im selling the burn2, HDR1, and blank chip for 75$ plus 5$ shipping! thats over 100$ in tuning equipment. shipping is limited to 48 continental states.
Car: 87 TA clone
Re: Moates TUNING stuff! i also do tunes
sry guys the stuff was sold a week after this thread started. I havent had much time to update the threads. I have other stuff im selling as well... grannelli MAF, an almost complete cruize control setup. some gauges etc
