[NJ] Trick Flow Cam and Lifters
Old Jul 28, 2010 | 01:13 PM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.10
I have a slightly used (properly broken in (30mins) and 15 miles driving)
Cam is Trick Flow® Track Max® Camshafts for Small Block Chevrolet (TFS-31401002) Cam is Hydraulic flat tappet with RPM Range 3,500-6,500 ,
Duration at 050 inch Lift 246 int./254 exh. , Advertised Duration 308 int./316 exh. Valve Lift with Factory Rocker Arm Ratio 0.510 int./0.518 exh. lift
Lobe Separation (degrees) 112 Asking 70.00 obo
I also have used lifters if anyone is interested. They are Trick Flow® Hydraulic Flat Tappet Lifters (TFS-21400001)Lifter Outside Diameter (in) 0.842 in.
It is a set of 16. They were used with cam listed it above. Asking 30.00 obo
Located in National Park, NJ 08063
Old Aug 9, 2010 | 11:25 PM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
Re: Trick Flow Cam and Lifters
TTT
Old Aug 17, 2010 | 11:55 AM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
Mickeyruder
Sep 2, 2015 02:45 PM
z28guy134
Sep 1, 2015 11:50 PM
Brendankup
Aug 30, 2015 01:46 PM
