9 Bolt disc plates, axles, rotors, diff cover
Old May 10, 2009 | 11:00 AM
sebowen's Avatar
Want a title? Post!
Axle/Gears: l
I have for sale:
Two 9 bolt 28 spline axles with good bearings and matching races $35 plus shipping
Two sets of 9 bolt disc brake plates $20/pair plus shipping
Two GM rear 10.5" disc brake rotors: $10 plus shipping
One 9 bolt differential cover with rubber drain hole plug: $5 plus shipping
Old May 10, 2009 | 11:31 AM
sebowen's Avatar
Want a title? Post!
Axle/Gears: l
Re: 9 Bolt disc plates, axles, rotors, diff cover
I also have the stock steel drive shaft with a 27 spline yoke (fits a T5 transmission). Well balanced and no play in the U-Joints $35 plus shipping
Old May 11, 2009 | 01:24 PM
GNTTA's Avatar
Any pics of the backing plates? Are these for a disc rear? If they are in excellent condition then I am very interested. What year car are they off of. Thanks,AJ
Old May 11, 2009 | 07:08 PM
sebowen's Avatar
Want a title? Post!
Axle/Gears: l
AJ, I have pictures of both sets of the 9 bolt rear disc brake plates. I can't seem to be able to attach them here so I'll try and send you a PM.
Old May 16, 2009 | 09:59 AM
sebowen's Avatar
Want a title? Post!
Axle/Gears: l
One set of brake plates SOLD. Still have another set. All other items still for sale.
Old May 17, 2009 | 06:15 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Are these backing plates for the PBR type or the old Delco Moraine iron calipers? Interested if they are PBR.
Old May 17, 2009 | 08:02 AM
sebowen's Avatar
Want a title? Post!
Axle/Gears: l
The disc brake plates are for the Delco Moraine iron calipers.
Old May 22, 2009 | 06:28 PM
sebowen's Avatar
Want a title? Post!
Axle/Gears: l
Bump
Old May 30, 2009 | 07:29 PM
sebowen's Avatar
Want a title? Post!
Axle/Gears: l
Bump
Old Aug 9, 2009 | 10:57 AM
sebowen's Avatar
Want a title? Post!
Axle/Gears: l
Bump
Old Aug 9, 2009 | 11:05 AM
Stephen's Avatar
Car: 87 GTA
Originally Posted by sebowen
I have for sale:
Shipping to 78605?
Old Aug 9, 2009 | 03:55 PM
sebowen's Avatar
Want a title? Post!
Axle/Gears: l
Originally Posted by Stephen
Shipping to 78605?
Shipping is $11 USPS Parcel Post ot $13.00 USPS Priority Mail to zip code 78605
Old Aug 9, 2009 | 04:08 PM
Stephen's Avatar
Car: 87 GTA
Hmmmm......
USPS Small Flat Rate Box, if it fits, it ships - $9.85 And the boxes are free.
And that is Flat Rate. A box that fits right, would likely be cheaper, since it isn't heavy.
But even at the Flat Rate price, I'm not paying more for shipping, than for the part itself.
Old Aug 21, 2009 | 08:47 AM
sebowen's Avatar
Want a title? Post!
Axle/Gears: l
Sorry Stephen, the differential cover doesn't quite fit in the USPS small flat rate box but does fit in the USPS larger flat rate box. Doubt you'd be able to find any carrier that would ship it from New York to Texas for under $5 (which is the price I was offering for the cover and plug) regarless of the packaging. Good luck though.
Old Aug 21, 2009 | 01:22 PM
kowalzekc's Avatar
Will the backing plates fit on a 93+ gm 10 bolt? If so, I will take the other set as long as they are in good working order.
Old Aug 25, 2009 | 05:50 PM
sebowen's Avatar
Want a title? Post!
Axle/Gears: l
No sorry. The 9 Bolt disc brake bolt mounting pattern is different than the 10 bolt.
Old May 26, 2010 | 12:11 AM
littlevin91's Avatar
Car: 1991 camaro z28 convertible
Engine: 5.0 v8
Axle/Gears: 9 bolt 3.23 borg worner
do you still have the differential cover email me at littlevin91@aol.com
Old Aug 17, 2010 | 12:53 PM
pheonixthree's Avatar
Do you still have the Disc brake backing plates? If so I am interested! It is for my 87 Trans Am with 9 bolt BW posi rear end. Old plates are prety rusted out!
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
sailtexas186548
Jan 19, 2016 12:21 PM
