Engine and transmission parts, tons of stuff
Old Aug 22, 2010 | 03:20 PM
chevy1500z71's Avatar
Car: Chevy truck
Engine: supercharged 355 tbi
Transmission: NV4500 manual
Axle/Gears: 14 bolt w/4.56 and detroit locker
i know its an atv forum but im just posting this on every forum im a member of, trying to get some of this stuff gone.
iv got an np241c transfer case that fits 88-95 chevy and gmc trucks. only has 150,000 miles on it and it works great, i payed $260 for it a few months ago, ill sell for $175
2 barrel holley carb, 600cfm, no choke- $75
set of moroso billet aluminum water pump and crank pulleys- $75
set of stock tbi truck heads, in fine working order-$100
set off #993 casting heads w/ good double valve springs and stainless valves, threaded for screw in rocker studs, 76cc chambers. they have been used only a few times since they were machined- $185
mechanical fuel pump and pushrod for sbc-$15
isky circle track cam and lifters, hydraulic flat tappet, used for 2 races, been sitting in the box ever since. have the cam card for it if theres interest- $110
kevko 7qt circle track oil pan, has baffles and trap doors, includes high volume oil pump and proper pickup- $75
10 bolt chevy rear end housing and chrome diff cover- $70
10 bolt chevy 30 spline axle shafts- $70
np241 transfer case for 88-98 chevy truck, manual shift, 27 spline input for half ton transmissions such as the 700r4, 5l60e, or nv3500.- $175
corvette servos for 700r4 or 4l60e transmissions, 88-98 chevy trucks, camaros, these will fit alot of cars and trucks, awesome improvement in shift firmness.-$60
any spare parts for a 4l60e such as sensors, pan, transfer case adapter, ect. just ask.
iv got probably 3 or 4 sets of stock type exhaust manifolds- $20 per set
iron intake manifold, looks to be for a 4 barrel quadrajet- $30
shorty headers for 88-98 chevy trucks, work fine but the flanges are split- $30
mr.gasket copper header gaskets, payed over 30 bucks for em and used them for a day- $20
3.55 gear set for 14 bolt semi floater 9.5" chevy rear ends, also have the carrier and spider gears which are in good shape-make an offer
4" conical k&n air filter- $25
circle track valve covers for sbc, outer bolt pattern- $25
Delco Hei distributor, has an aftermarket coil, worked good when removed- $35
Comp Cams high tech pushrods, 7.650 length, used for 2 races, been sitting since- $75
set of 3/8" rocker studs and strait guideplates- $35
stock center bolt valve covers for sbc, good shape- $15
168 tooth summit flex plate for 2 piece rear main seal sbc, sfi approved. used for about 4,000 miles- $30
168 tooth flexplate for 1 piece rear main sbc, stock gm piece- $25
168 tooth flywheel for 12" clutch, came from a 95 big block chevy truck, looks like the bolt pattern also matches 1 peice rear small blocks. good for nv4500s, sm456, ect. its an oem gm piece, resurface it and its better then any Chinese parts store flywheel.- $95
transfer case shifter and plastic cover for 88-98 chevy trucks, plastics a little rough- $30
Old Aug 23, 2010 | 09:03 PM
dcktp37's Avatar
Car: '89 Chevy C1500
Engine: 355 TBI
Re: Engine and transmission parts, tons of stuff
Was the fan in pic 1 for sale?
Old Aug 24, 2010 | 09:15 PM
Car: Chevy truck
sorry, fan sold long ago.
everything in the first pic is still available except the fan and the muffler. also forgot to list the racing mini starter in the pic, it needs a new gear but its good otherwise.
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
milk
Aug 10, 2015 06:26 PM
1nastygta
Aug 8, 2015 07:38 PM
