Garage cleanout! ECM's, prom, flywheels, alternators, misc parts
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Hey guys, as the title says I'm trying to clean out some stuff I've had lying around. Most of the stuff is B.O. unless otherwise stated.
Centerbolt valve cover gaskets, felpro, brand new B.O.
TPIS custom burned PROM. Out of 86 trans am, it was burned for a 350 with Trick flow heads, Comp XR276 cam, and a mini ram with 30 lbs injectors and an MAF set up. As long as you use 30 lbs injectors and a heads and cam motor I think it will be generally close in the tune. **SOLD**
I have 2 7165 ECM's. One is bent where the PROM cover goes on since there was a custom chip with a cable mount on it, but they both worked fine when removed. B.O. One left, other is SOLD
Buffer box for speedo. I have no idea what this will work on. Came out of 86 trans am with a 305 TPI and auto trans. B.O.
Car: 1986 Trans am
Engine: 5.3 LM7
Re: Garage cleanout! ECM's, prom, flywheels, alternators, misc parts
Chrome alternator mount for a basic carbed SBC. B.O.
2 alternators. Both the 86 and below style. One has a V belt pulley, other has a serpentine pulley. Both worked perfect when removed. B.O.
Tranny mount for either auto or manual trans in nice shape and a 3 prong oil pressure sensor with block mount. No idea what year the sensor is off of. B.O. for both
Car: 1986 Trans am
Engine: 5.3 LM7
Centerforce billet steel 153 tooth flywheel for 400 engines (possibly 383 as well). Never been resurfaced. In great shape with a little surface rust forming. 310$ new. Asking 125 + shipping
Car: 1986 Trans am
Engine: 5.3 LM7
Stock flywheel for T5 set up. I believe it is a 153 tooth. Not sure what it's out of. Possibly off of 6 cyl...not sure if they are the same? B.O.
is the centerforce flywheel for a 1 piece rear main? Did you have the VATS and EGR removed when the chip was burned?
Car: 1986 Trans am
Engine: 5.3 LM7
As far as the PROM, EGR was removed as I had no emissions equipment on the engine at all. My car was an 86 as well so it never had VATS, so yes that is removed as well. No cold start injector either...I had that removed from the tune.
Let me know if you need any other info.
Car: 1986 Trans am
Engine: 5.3 LM7
PROM and one of the ECM's are sold. Other parts still available. Pending sale on stock flywheel.
Sanjay
08-12-2015 03:41 PM
3rdgenparts
08-05-2015 11:57 PM
