[IL] 383 Stroker SBC
Old Oct 9, 2010 | 01:06 PM
Fallen2603's Avatar
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
383 Stroker SBC
Small Block Chevy 383ci Stroker:
Eagle cast steel crank (3.75" stroke)
Scat forged connecting rods
Sealed Power flat-top hypereutectic pistons (0.030" over and 10.4:1 CR)
Lunati Voodoo Hydraulic Flat-Tappet Cam (PN 60103) with an RPM range of 1,800-6,200, advertised duration of 268/276, duration @ 0.050" of 227/233, and a gross valve lift of 0.489/0.504
Edelbrock Victor Jr. Cylinder Heads with 215cc intake runners and 64cc combustion chambers
Comp Cams Magnum pushrods
Aluminum 1.5 ratio rocker arms
Weiand single-plane aluminum intake manifold, NOT INSTALLED
ARP fasteners throughout
Moroso 6qt oil pan for 3rd-Gen F-Body (may fit other applications)
March Performance Revolver Serpentine Kit with 105 amp alternator and power-steering pump
High-torque Mini-Starter, NOT INSTALLED
The engine has not been on the dyno, but best guess is the engine was pushing at least 450hp with a restrictive TPI setup. Two 700R4 transmissions, one of them built to handle the power, were junked by this engine.
I'm asking $4,000 or best offer. If interested, reply to this ad with your phone number, and I'll call you ASAP. NO LOWBALLING.
Old Oct 11, 2010 | 08:36 PM
redltcamaro's Avatar
Car: 1987 LT Camaro
Engine: Empty at the moment
Transmission: thats out too
Axle/Gears: 4.11
Re: 383 Stroker SBC
nice price but i think the hp is way off there is no way with a stock tpi that you would make that much hp maybe torque
Old Oct 11, 2010 | 09:54 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: 383 Stroker SBC
Thank you, I know it's a nice price.
First, who said that TPI setup was "stock"?
Second, why does it matter if I'm selling it with a Weiand, High-Rise, Single-Plane square-bore intake manifold?
Old Oct 11, 2010 | 10:26 PM
Car: 1987 LT Camaro
Axle/Gears: 4.11
Re: 383 Stroker SBC
sorry didnt see that part hp seems a little more believable with that intake
Old Oct 22, 2010 | 09:06 AM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: 383 Stroker SBC
BUMP.
Old Oct 28, 2010 | 10:25 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: 383 Stroker SBC
BUMP.
Old Nov 1, 2010 | 08:39 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: 383 Stroker SBC
ENGINE ONLY for $3,000 OBO.
SERPENTINE KIT ONLY for $1,400 OBO.
Old Nov 5, 2010 | 09:20 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: 383 Stroker SBC
BUMP.
Old Nov 6, 2010 | 11:12 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Re: 383 Stroker SBC
Where are you located??? I may be interested depending on what I find out with my rear...
Old Nov 6, 2010 | 06:08 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: 383 Stroker SBC
PM sent.
Old Nov 8, 2010 | 07:09 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: 383 Stroker SBC
BUMP.
Old Nov 12, 2010 | 01:09 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: 383 Stroker SBC
BUMP.
Old Nov 16, 2010 | 07:11 AM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: 383 Stroker SBC
BUMP.
Old Nov 17, 2010 | 09:25 AM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: 383 Stroker SBC
BUMP.
Old Nov 17, 2010 | 10:29 AM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Re: 383 Stroker SBC
I'm also interested on the location of the seller. Depending on far the seller is, I might be interested.
Old Nov 17, 2010 | 12:55 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: 383 Stroker SBC
all4u,
PM sent.
The motor is located near Serena, IL.
Old Nov 19, 2010 | 04:10 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: 383 Stroker SBC
BUMP.
Old Nov 21, 2010 | 04:21 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: 383 Stroker SBC
BUMP.
Old Nov 23, 2010 | 12:43 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: 383 Stroker SBC
BUMP.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
