[IL] SBC 350 motor
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
SBC 350 motor
I have a 1979 Chevy 350 SBC its out of an old van that the body went to hell on. It was supposed to have only 30k on it but im pretty sure thats not true because it has some serious crankwalk. It has 130-150 compression on all cylinders cold. It needs crank bearings and a timing chain for sure. It will come with everything but carb. I have a stock 4 barrell Intake and a 2 barrel Intake also have a set of swirl port heads to go with it also and a set of stock exhaust manifolds. Will also include Starter, alternator, power steering pump, water pump,exhaust manifold gaskets only been on for 15 mins run time max and 2 mechanical fuel pumps. I would like $400 obo for motor with everything. Will be getting pictures up soon. Here are some pictures of the head numbers.The 624's are the heads on the motor now. The swirl ports have valve and springs but no rockers. The block is a 4 bolt main.Does have new rear main seal. Does not include edlebrock intake thats pictured,chrome breather, or flexplate. Will trade for SBC performance parts or some parts for a 1992 firebird such as suspension parts or a passenger headlight motor.
evilstuie
Jan 9, 2020 08:29 PM
