[Sold] C5/C6 Rear brake conversion
Car: 1970 Nova
Engine: 850HP 383
Transmission: TH400 w/ Brake
Axle/Gears: 4.88 12 Bolt
Setup consists of backing plates,shoes,springs,adjuster abutments.The picture only shows one side.But both sides are included. Basically everything pictured and they are all new GM parts from the dealer.Looking to get $185 shipped obro.To buy this from the dealer would cost close to $400.
You will need to buy the conversion brackets to mount this to a 10/12 bolt
Any questions feel free to ask
Car: 1970 Nova
Engine: 850HP 383
Re: C5/C6 Rear brake conversion
TTT
Add Ebmillers brackets, set of calipers and rotors and have a complete brake conversion
Car: 92 z28 vert
Engine: ls6
Transmission: t56 magnum
Axle/Gears: moser 9 inch 4.11
let me see if i can get these to work with what i have i have a moser 9 inch with ed's brackets and c6 z06 calipers what is the least you will take for them thanks
Car: 1970 Nova
Engine: 850HP 383
Do you have the brackets that bolt caliper right to the housing? If so you'll need Eds other brackets that bolt these to housing cause this is the setup so you can use the ebrake also.
Edit: Stupid me didnt see the Moser part at first,you may have to ask Ed on the brackets then
Car: 1970 Nova
Engine: 850HP 383
$160 shipped
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
I'm highly interested. So basically I have a 10 bolt drum rear end. If I got this i would disassemble all my drum peieces and use the bracket you supply and bolt this right up?
Only thing missing is brake pads and rotors?
Car: 1970 Nova
Engine: 850HP 383
Youll need these brackets also
http://flynbye.com/catalog/i76.html
