[OK] MSD Pro Billet & Fast XFI parts FS
Changed the plans on the car and now going with a Blow-Through carb.
First, I have an MSD Pro- Billet TPI Drop-In Distributor, Part # 8366 with a Bronze Gear.
Only has around 200 miles on it. No Flaws whatsoever. Bought it and installed the bronze gear for my roller cam... had it out of the garage 4-5 times. Guranteed to work.
MSD has been taken off the market... Looks like it will work well for my carb project
Next, FAST XFI Harnesses, Brand New in Box
Part# 301100 Wiring Harness, Fast XFI, Main Harness, GM TPI Kit Circuit Diagram
Part# 301200 Wiring Harness, Fuel Injector, 18436572 Firing Order, Universal, Kit Circuit Diagram
Part# 301300 Ignition Pickup adapter Harness for IPU Distributor Circuit Diagram
SOLD!Part# 301406 Fan & Fuel Pump output Harness Circuit Diagram
SOLD!Part# 301402 Auxilary Analog Input Harness for Inputs such as Fuel Pressure, etc. Circuit diagram (scroll down to 402)
SOLD!Part# 301403 VSS and Aux Shaft Harness for Vehicle Speed InputCircuit Diagram
PM me on cost of other harnesses
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: MSD Pro Billet & Fast XFI parts FS
What module will be needed to complete the swap and will that be all it needs? I would be using this on a 92 Z28 with a holley stealth ram and 700r4 trans.
E-mail me at; allen.bray64@yahoo.com
The only thing needed will be the main computer module. My original plan was to buy the harness and get it installed and buy the module last from my tuner and have him stick a base tune into it and be able to just plug it in. That was before my tuner retired last month and right after I got the harness...
TTT! $375 shipped for whats left! Plug it into your stock sensors, get an ECU, and GO!
9192camaro
16
Feb 3, 2019 12:21 AM
