Crane HI-6RL ignition 6000-6463
Car: 1987 camaro lt
Engine: soon 383
this item is brand new in the box a customer had me order this and never came back for it i have no paper work on this item but if you need it you can find it on cranecams.com..
Crane HI-6RL ignition 6000-6463 sells for 300$
Product Description:
Fully digital design.
Multi-spark CD ignition
Potted with soft urethane to seal from dirt, oil, moisture and vibration.
LED light for power and trigger signal.
Lightweight aluminum housing with cooling fins.
Preset rev limiter in factory "sealed" unit per sanction rules.
Weatherpak connectors.
Mag trigger input.
Tachometer input.
Tech Notes:
Operating Voltage: 6 to 18v, reverse polarity protected, neg. ground only.
Current Draw: 7.0amps max.at 10,000 RPM
RPM Limiter Accuracy: ±30 RPM
Timing Accuracy: ±0.5 degrees from 500 to 9,900 RPM
Primary Voltage Output: 450Volts
Primary Energy Output: 1200 millijoules/sequence
Peak Spark Gap Current: 380 Milliamps with LX91 coil, 510
asking 180$ +shipping will only accept pay-pal
anderson SC
Mag trigger input.
Tachometer input.
Tech Notes:
anderson SC
Hotrodboba400
Dec 10, 2019 07:07 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
