T5 and everything for auto to manual swap
Old Mar 2, 2011 | 09:21 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
T5 V8 and accessories,,,transmission nwc(26 splines),,,shifter +****-bellhousing-fork-throw out bearing-hydraulic slave and reservoir with brackets for the bell and firewall- clutch/brake pedals and 5 speed shifter(camaro) plate..all you need is the flywheel and clutch kit.,. i have seen this set up on ebay go for over $1000,,but i was thinking more like $800,,,can ship with fed ex ground ,,it's pretty cheap and economical shipping service.
Old Mar 3, 2011 | 06:20 AM
Italianguy63's Avatar
Car: 1936 Chevy Master (Project)
Engine: 1993 LT1 350 - Z28
Transmission: 4L60
Axle/Gears: Jaguar 2.88
Re: T5 and everything for auto to manual swap
What is the # on the gearbox 1352-xxx? I'm looking for a WC unit. MC
Old Mar 3, 2011 | 08:41 AM
mooch1's Avatar
Transmission: T5 WC
it is a nwc 1352-028...but wc or not,,they are about the samwe when it comes to power handling,...thanks,
Old Mar 3, 2011 | 08:57 AM
Transmission: 4L60
There actually is a difference in the power handling (250 ft/lbs vs. 300 ft/lbs)... I have a NWC, and seeking a WC for use behind a stout 350. Thanks for your help, it just isn't what I need. Good luck! You have a V8 unit there with good gearing... somebody will want it! MC
Old Mar 3, 2011 | 01:20 PM
mooch1's Avatar
Transmission: T5 WC
ok, no problems ,,but according to the T5 websites...the torque difference between nwc and wc is about 20-25 lbs ..if it's pushed hard,,either model will break..
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
