Trick Flow G1's Fully Ported SBC
Old Apr 9, 2011 | 03:04 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
I have a set of G1 Trick Flow Twisted Wedge heads for SBC. They are the first design that outflow all later designs. These have been fully race ported and outflow most other heads on the market. Dual springs for a .600 lift roller cam installed. They have receiver grooves cut for O-ringed blocks/copper head gaskets. These have about 10 miles on them since being rebuilt (new guides, springs, and seals) $1000 plus shipping
Flow Sheet
http://http://i1106.photobucket.com/.../FlowSheet.jpg
Old Apr 9, 2011 | 03:16 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Re: Trick Flow G1's Fully Ported SBC
I have a set of these and I have a few quick questions. Did you have to run special pistons with them and what rocker arms did you use? Thanks. GLWS.
Old Apr 9, 2011 | 07:18 PM
91 1LE's Avatar
Car: '91 1LE
No special pistons required. I used forged flat-tops with stock valve reliefs and had no piston-to-valve clearance problems. Trick Flow has a list of rocker arms that work with these heads that don't prematurely wear the valve guides.
These heads also include screw-in studs and guideplates.
Old Apr 9, 2011 | 10:04 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
also note.the pushrods should be .750" longer than your normal stock sbc pushrod......i used to run a set of these heads and alsways had perfect valvtrain geometry...........def a decent cylinder head...........
Old Apr 10, 2011 | 08:55 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
I had a set of these too. They were a real decent set of heads. Got me like 330rwhp with a very mild cam and miniram. Good luck with sale!
Old Apr 10, 2011 | 02:36 PM
91 1LE's Avatar
Car: '91 1LE
These heads made 425HP and 450TQ on a flat-top 377 shortblock with a smallish 224* duration cam.
I don't recall which length pushrods I used. I always mock-up my builds and measure the correct length and order them accordingly.
Old Apr 25, 2011 | 06:23 PM
91 1LE's Avatar
Car: '91 1LE
I will throw in a brand-new set of fabricated valve covers for the same price if someone is interested. And I can have the receiver grooves removed as well for a standard head gasket installation.
PurelyPMD
May 5, 2016 04:57 PM
69GTOby
Apr 18, 2016 02:34 PM
BWilcox
Sep 20, 2015 12:19 PM
toronto formula
Sep 10, 2015 07:31 AM
hdis2002
Sep 8, 2015 02:52 PM
