[NH] Painless Performance TPI VATS Module
Car: JEEPS
Engine: TPI 350
Transmission: TH400
Axle/Gears: 6.72 detroited 2 1/2 ton Rockwells
Hi All! I have abandoned my TPI project and came across this module that I never used. This is the painless way to bypass the VATS.
Part number 64023
$50 bucks on summit: http://www.summitracing.com/parts/PRF-64023/
Lets do $30 with free shipping
Part number 64023
Since 1989, most GM fuel injection systems have incorporated a Vehicle Anti-Theft System (VATS) programmed into the stock EPROM or PCM. This means the engine will not run if it is transplanted into a vehicle without the original vehicle steering column and decoder module. If you have one of these engines and your computer has the factory programming, you will need a Painless VATS computer chip. These chips allow you to bypass the factory programming, making the wiring in your engine swap a snap.
Car: JEEPS
Engine: TPI 350
Transmission: TH400
Sanjay
Aug 12, 2015 03:41 PM
