[AZ] LS1 injectors and other stuff FS
Car: 01 Z28 / 85 TA
Engine: 346 /355 V8
Transmission: 4L60E /700R4
Axle/Gears: 10 bolt 3.73 / 9bolt 3.27
Selling the following:
A set of flow matched (I have test data from Rich at cruzinperformance.com to prove this, pm me for it) LS1 injectors. Bosch part# 0 280 155 890, they flow ~22.5 lbs/hr at 43.5 psi and 26 lbs/hr at 58 psi. $120 obo
A set of 14" wheels with fresh 235/60 R14 tires. They work fine on thirdgens or probably anything else with a 5 on 4.75" bolt circle. One wheel has a part of the wheel weight lip bent, but all the wheels do balance successfully. Will post pics later. $220 obo (check my local board post for pics https://www.thirdgen.org/forums/sout...her-stuff.html)
A steering column from an 88 firebird, has an aftermarket hub adapter installed, has cruise control provisions. $60 obo
92 V6 Firebird instrument cluster odometer shows ~174K, all gauges work. $30
92 Firebird A/C / Heat control head. Slider (as opposed to push-button) type. $10
88 Firebird Brake booster. Worked when it was pulled, however the master cylinder rod is missing. $20 obo
88 L98 roller cam made by Melling. Check the tech pages for specs. Run for 20K miles before being replaced with a hotter comp cam. $50 obo
Hawk312
Aug 22, 2017 08:55 PM
