[PA] 89 IROC Partout
Car: 87 GTA
Engine: 383
Transmission: T350
Axle/Gears: 9 INCH-3.89
89 IROC Partout
I picked up an 89 IROC for parts this past weekend. The car has **NO** motor. It was a 5.7 ltr. tuned port car. For now I'm going to be keeping the doors, spindles, rear brakes, fuel tank, stereo system, front sway bar, t-tops/t-top bar, fans and radiator. The IROC wheels, Hood(good shape, just needs paint), 700r4(w/converter), 5.7 ltr. ECU(doesn't have a prom chip), 9 bolt rear (with 2.77 ratio), factory suspension, interior, pretty much the rest of the car is up for grabs. The ground effects may be spoken for already but will know better later this week. I there is anything you want pictures of, let me know. Not really interested in shipping any of the big stuff.
[SOLD] Iroc wheels--$200
[SOLD] 700r4 trans w/converter--$150
(SOLD) 9 bolt rear--$150
5.7 ltr. TPI ECU--$50 shipped
[SOLD] Hood--$100
[SOLD] Air intake system w/K&N filters and MAF--$100
[SOLD] Inst. cluster--$75 shipped
(SOLD) Tail lights--$80 shipped
(SOLD) Rear spoiler--$60 shipped
(SOLD) Steering column--$100 shipped
[SOLD] Hood--$100
Car: 87 GTA
Engine: 383
Transmission: T350
Re: 89 IROC Partout
Keeping the doors. There is a list in the original post of things I'm keeping. I have someone ahead of you for the ground effects. If that falls through, I will let you know.
Re: 89 IROC Partout
Would you let the spoiler go? I bought an '87+ third brake light spoiler a while ago off of here, then I accidentally cracked it. So I've been looking around for another one.
Car: 1989 IROC Z
Engine: 5.0 tpi. stock [for now]
Re: 89 IROC Partout
Car: 87 GTA
Engine: 383
Transmission: T350
Re: 89 IROC Partout
I believe so. That's on the drivers side of the firewall beside the brake booster right?
Car: 87 GTA
Engine: 383
Transmission: T350
Re: 89 IROC Partout
Not sure about that. The guy we got the car from said the tranny had been replaced so its not the original tranny. He said it ran fine though.
Car: 86 z28
Re: 89 IROC Partout
is there fluid in it and is the trans in the car or allready out i just wouldnt want to buy the trans just to have it blow again
Car: 87 GTA
Engine: 383
Transmission: T350
Re: 89 IROC Partout
I didn't check with the dipstick yet but when I took the convertor off there was fluid in it. The trans is still hanging in the car. Didn't get to pull it yet.
Car: 86 z28
Re: 89 IROC Partout
well if you check and see the level and see the color and smell to see if the fluid smells burnt for the price i am very interested wouldnt be able to get out to see it till sunday at the earlyist though
Car: 73 Camaro
Engine: 355
Transmission: TH350
Axle/Gears: 3.23 posi
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
Re: 89 IROC Partout
If you change your mind and leave the brakes on the rear I'll buy it
Transmission: t56
Car: 87 GTA
Engine: 383
Transmission: T350
Re: 89 IROC Partout
Just the harness? $15 I guess. I need to check to make sure the previous owner didn't cut anything up. I noticed some cuts in a few spots in the engine harness.
Car: 87 GTA
Engine: 383
Transmission: T350
Re: 89 IROC Partout
jfelte, I checked the fluid today and it looks good, doesn't smell burnt and the fluid level is good.
Car: 86 z28
Re: 89 IROC Partout
thank you could you pm me with some contact info as i am sure we will be getting this from you as soon as we can make it out there
Car: 87 GTA
Engine: 383
Transmission: T350
Re: 89 IROC Partout
Pro69ss, the piece you were asking about is FUBAR. I have another one somewhere, just need to remember where I put it. I will let you know.
Car: 1988 IROC-Z
Engine: 5.7 TPI with zz4 heads
Axle/Gears: 9 bolt BW
Re: 89 IROC Partout
does it have the silver IROC emblem on the driver side rocker...if so ill take it
Car: 87 GTA
Engine: 383
Transmission: T350
Re: 89 IROC Partout
The car had a flowmaster 3 inch catback on it and my brother already got that. Pab's, I pulled the ground effects off today and for now I have someone interested in the whole set.
Car: 73 Camaro
Engine: 355
Transmission: TH350
Car: 87 GTA
Engine: 383
Transmission: T350
Re: 89 IROC Partout
Amazing what can happen in a week!
I'm going to be stripping whatever else I can this week. This car has 1 more week on my trailer and then it will head to its final resting place.
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
Re: 89 IROC Partout
Im in need of the intake TPI ECU can you send pics to 248-762-6235 or neeb_usmc@yahoo.com.. thanks
Car: 89 camaro rs
Engine: 468 bbc
Transmission: powerglide
Axle/Gears: 373 S-60
Re: 89 IROC Partout
I need the brackets under the sail panels that hold the rear speakers in. Let me know if you have these. Also need rear seat belts,(if right colors). Thanks shipped to 15670.
Car: 87 GTA
Engine: 383
Transmission: T350
Re: 89 IROC Partout
Looks like the previous took the rear speaker brackets out. The rear seat belts are gray. $30 shipped for the seat belts.
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: 89 IROC Partout
The body portion of the under hood harness available? C100 firewall conector to wipers, AC and starter.
Car: 1985 IROC
Engine: L69
Transmission: 5spd
Re: 89 IROC Partout
is the dash in good shape? I would also be interested in interior parts doors (not sure if you want the interior door parts) and hatch parts.
Ed
Ed
Car: 87 GTA
Engine: 383
Transmission: T350
Re: 89 IROC Partout
ACCLR8N, I'm pulling the whole underhood harness out. The only thing I cut off so far was the fuel pump relay for another member on here.
EJ2, let me know exactly what parts you want. I'm trying to get as much out in the next few days so the car can be removed.
Car: 87 GTA
Engine: 383
Transmission: T350
Re: 89 IROC Partout
Hotrodtech, I have a guy that's supposed to be coming this weekend for that. I will let you know if anything changes.
Re: 89 IROC Partout
Car: 87 Iroc Z 28
Engine: 355/ 600 Holly
Transmission: 700R4 shift kit & vette servo
Axle/Gears: 9 bolt 3;70s
Re: 89 IROC Partout
Do you still have the grant steering wheel with all attaching hardware, How much shipped to 48127
