[IL] New McCord Power Plate 3" Cutout & JFZ Front Brake Kit 4 Pistons!
Old May 17, 2011 | 06:36 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I have one Mccord 3" Power Plate (electric cutout). Brand new just found it in my garage. I bought it many years back through a GP here on TGO. I have no need for it. It has the full wiring, quick disconnect harness, rocker switch, led, and locking connector for the 12v power. I've never even put power to it. $100 Shipped
I have a used JFZ Brake Kit. It contains 12.2" x 1.25" Rotors with 4 piston calipers. I believe the calipers are 1.75" pistons. These use a wilwood type brake pad. Rotor size and thickness I wouldn't be affraid to run these on the street. The calipers rub a little inside a 15" draglite rim. It might clear barely with a spacer, but I would just recommend using a 16" or larger rim. I have stock spindles modded, tapped, painted, and mounted. I also cleaned up the inside of these calipers with denatured alchol and tapped them to accept the standard metric GM bango bolts. I assembled these around this time last year. I was going to use these on the street, but plans have changed. I'm getting ready to install drag struts, springs, shocks, and etc. I don't need extra stopping power if I go with a skinny tire. I would like to get my materials cost back out of them (eBay kit, replacing missing bolts with grade 8, buying spindles, etc). Not included is my hours of using a hack saw to modify the stock spindles, tap bolts, loctite everything, pack bearings, and etc. The calipers are in unknown condition as I have never used them. Minor surface rust on the rotors now. It should just scruff off. $500 + Shipping... SOLD WILL SHIP 2/6/12
Mock up in a 15" rim without it assembled:
Assembled on the spindles:
Old May 31, 2011 | 08:34 AM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: New McCord Power Plate 3" Cutout & JFZ Front Brake Kit 4 Pistons!
I'll keep it in mind. Running from a cut out on the street might sound a bit raspy. The cops around here don't seem to bother with loud exhaust, but They're A** H****'s around here about everything else.
Old Jun 9, 2011 | 12:54 PM
Engine: 383 SBC
BUMP.
Old Jun 9, 2011 | 02:14 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Pics of the cut out im interested in it.
Old Jun 9, 2011 | 09:19 PM
Engine: 383 SBC
Might also have the flowtech weld in cut out too if you want to give me a few more bucks for that also.
Here's the McCord Power Plate [pic is clickable for larger view]:
Old Jun 13, 2011 | 06:00 PM
Engine: 383 SBC
BUMP. Still need to sell.
Old Sep 14, 2017 | 09:10 AM
tbroherd's Avatar
I know it's an old post but do you still have the JFZ brakes? Have more pictures?
Old Sep 14, 2017 | 09:44 AM
Engine: 383 SBC
nope they are gone. I have more pictures on my car domafin page.
http://www.cardomain.com/ride/433125...tiac-firebird/
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
red90IROCls1
Aug 25, 2015 06:56 AM
