[IL] 355 roller, comp cam, trick flow heads,arp,,all reciepts
Old May 31, 2011 | 08:53 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
The motor has @ 7k miles on it, 355, lt1 crank, arp studed mains, arp rod bolts and arp head bolts,arp cam bolts and studed oil pump bolt with solid pump shaft. speed pro pistons, zero decked, double roller timing chain, comp cams custom grind 227/234 with .560 lift and 112lsa(i have the cam card) trick flow 195 heads rebuilt lightly ported, 1.46 dual springs, new bronze guides, valve job, 7/16 arp studs gasket matched for 1205, stock roller lifters. I have reciepts for all of the machine work, head work, arp fasteners, cam, timing chain,,,etc... it held 40psi of oil pressure at idle and ran very strong,,, it was built about 5 years ago. $1500 picked up and no I will not seperate anything. thanks
Old Jun 15, 2011 | 01:16 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Re: 355 roller, comp cam, trick flow heads,arp,,all reciepts
Old Jun 22, 2011 | 01:46 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
sold
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
