[FL] 3.07 gears and differential
Car: 88 Trans Am
Axle/Gears: Posi
They are from a gm 10 bolt rear axle 3.07 gears 13:40. open Differential also for sale. I also have the axles which will be scrapped. I do have everything to make one complete axle.
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: 3.07 gears and differential
how much for the gears, differential and axles? Is it Posi? Which taillight style do you have?
Car: 88 Trans Am
Axle/Gears: Posi
i have two sets of gears i have a 3.07 set that is on an open differential and a 3.23 set on a posi diff. both 10 bolt axles
Car: 88 Trans Am
Axle/Gears: Posi
yes an open diff will do a 1 wheel burnout
positraction will do a 2 wheel burn out.
The gears are seperable from the differential unit so if you want posi 3.07 i should be able to do that as well or open 3.23
Car: 88 Trans Am
Axle/Gears: Posi
the 3.23 posi is currently in a rear end ( ive already taken the disk brakes but can include a set of drum brakes in very good shape) i would take 90 for the whole rear end
the 3.07 open differential is seperate from the rear end
Car: 88 Trans Am
Axle/Gears: Posi
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
How much with shipping to 30720 for the posi carrier/3:23 without housing?
I need one for my 03 S10. It can use the 3 series carrier with 28 spline axles.
dbrochard
Sep 19, 2015 08:13 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
