Comp Cams 292XFI
Old Jul 6, 2011 | 04:53 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Transmission: 97GM BW T-56
Axle/Gears: 9", Moser 31 Splines 3.73s Trac Loc
Comp Cams 292XFI
Long story short, bought this cam for my new motor. Took it to the dyno, and with my setup (E85), my tuner said it would be better and more drivable on the street if I get something smaller. It's in the car. You can hear it run. Still have the box and paperwork. Probably doesn't have 20 miles on it. Hydraulic Roller Tappet. Pretty big. Set up for blocks originally equipped with factory roller lifters (ie 87 and later). It would work on earlier blocks with a cam button also. 8-468-8 is the part number.
Specs:
http://www.compcams.com/Company/CC/c...?csid=177&sb=0
I paid a little $310 from JR Motorsports for it, but it's cheaper on Summit:
http://www.summitracing.com/parts/CCA-08-468-8/
$225
Old Jul 6, 2011 | 10:39 PM
karl's-92'-z28's Avatar
Car: Too many cars
Re: Comp Cams 292XFI
would it work on a stock 91-92 TPI motor?
Old Jul 6, 2011 | 10:55 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
No. It's one of the biggest hydraulic roller in the XFI line. As the cam card states on the link, your motor needs full mods to take advantage. The stock TPI will never be happy with this cam.
Old Jul 6, 2011 | 10:57 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Lol, yeah. You could try it if you wanted to, but I wouldn't recommend it. It'll fit, but you'll have to upgrade your springs and converter
Old Jul 7, 2011 | 12:56 AM
Car: Too many cars
How bout a stock bottom half, heads, miniram & supercharger top side?
Old Jul 7, 2011 | 02:56 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
You'd end up with a 10 second ride... before the pistons say bye bye.
If you had a stronger bottom end, and some decent heads, this cam would probably suit a miniram and stick shift or 3500+ RPM stall well. Supercharged and a little lower compression, and you'd have yourself a decent race engine!
Old Jul 7, 2011 | 09:06 AM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
With a good top end like that, you'd be flowing enough air to make this cam worthwhile and would actually be a pretty decent fit. Throw some pistons in it and call it a day. 10s would be pretty attainable at that point. Just need to make sure you have heads set up to handle .600 of lift.
Old Jul 7, 2011 | 12:15 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
The cam is designed for an engine around 383+ci with a 200+cc head with 10.5:1 or better CR.
I bet if you put this cam in a stock motor it would make less power than it does with the stock cam. haha
Old Jul 8, 2011 | 03:24 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
But would have a wicked idle
Old Jul 8, 2011 | 04:43 AM
Car: Too many cars
What would be good set of heads?
Old Jul 8, 2011 | 10:44 AM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Depends on your compression, Intake setup, displacement, etc. Dart Pro1s are a good all around cylinder head that can be bought decently cheap. Iron Eagles are ok if you're on a budget. I'd probably say anything with some larger valves in them.
Old Nov 7, 2011 | 09:59 AM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Still got this. Hear it run soon before I pull it out.
Old Nov 8, 2011 | 06:59 AM
Davejs's Avatar
Thats bigger then what I have in my 383 with a HSR and Dart Pro 1 Heads I'm undercammed with 450HP 465TQ Whoever drops that bad boy in will have a good 500+ HP with a set up like mine. I don't have Hyd Rollers or I would jump on it.
Old Nov 9, 2011 | 11:34 AM
dannyvera778's Avatar
Car: 91 camaro
Engine: LS3
love this cam got it in my lt1 with 1.65 roller rockers 355 forged, this things top end is rediculous since i change my roller rocker the lift is 604 and 599...love this cam
Old Nov 9, 2011 | 07:46 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
How was tuning?
Old Nov 14, 2011 | 12:36 PM
Car: 91 camaro
Engine: LS3
actuallygot the aldl cable and recorded all my data and sent it to this guy http://www.lt1pcmtuning.com/service/
and then flashed it on my pcm via email pretty convenient
Oh by the way its my daily driver cause im an -hole!!
Old Dec 3, 2011 | 05:37 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
I still have the cam for sale and in the car at the moment guys. You can hear it run before it gets taken out. I would also trade for a 280-268 XFI cam as well. Make me an offer if you're interested.
Old Feb 6, 2012 | 01:33 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Anybody interested in a big cam?
Old Feb 7, 2012 | 12:24 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
I have the XR294 in my car......you definitely need stall, heads and an upper intake that breathes.
But these things sound absolutely amazing!!......and yep, I still drive my car on the street. The car did have to be tuned.
Free bump.....
Old Feb 7, 2012 | 06:42 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Originally Posted by heat seeker
I have the XR294 in my car......you definitely need stall, heads and a upper intake that breathe.
Free bump.....
On pump gas at 11.8:1? That's pretty impressive.
Old Feb 8, 2012 | 06:38 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Yep, crazy huh? These cams have alot of overlap, which allows cylinder pressure to bleed off, so you can run high compression and still drive it on the street. But, I do it with aluminum heads, electric water pump, and dual fans running the whole time. Less heat = less detonation.
The tune is probably the most important......the idle can be kinda tricky.
Old Feb 13, 2012 | 07:01 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
I'm running 11.5/1 on E85. Tuning was a nightmare and evidently pretty tough to get driveability in the low throttle values.
Old Mar 15, 2012 | 10:22 AM
blackroc68's Avatar
I have a comp 280xfi! I may be intrested do you still have this cam?
Old Mar 15, 2012 | 12:22 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
I do! Was going to order a 280 this next week. If you're interested in swapping out, let me know.
Old Mar 26, 2012 | 07:15 AM
BApower's Avatar
Car: 2500hd,is300,91z,03pete379
Engine: 6.6,3ltr,lt1,600hpC15
Transmission: auto,auto,t56,13spd
Axle/Gears: 373,?,410,370
did you sell it or swap it yet
Old Mar 26, 2012 | 07:20 AM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
I have not. Car is torn apart for paint and sound deadening at the moment, so swapping the cam is on the back burner till that is done.
My 292 is still available to anybody that wants it. There seems to be some interest every once in a while, but every time I respond, that's when the interest stops. I'd love to just find someone that wants to swap for a 280XFI. IDK, we'll see.
Old Mar 26, 2012 | 07:50 AM
BApower's Avatar
let me what you will take for it shipped
Old Mar 26, 2012 | 10:27 AM
blackroc68's Avatar
<I have a 280xfi in my car now.I was going to buy it from you but my funds are low.I was trying to sell my car.I didnt want to pull it. .If the deal falls through pm me.
Old Mar 26, 2012 | 05:52 PM
BApower's Avatar
blackroc how much you want for 280 xfi
Old Mar 26, 2012 | 06:57 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
I want a 280 XFI. I'd trade straight across.
Otherwise, I'll take $225 + shipping. It's got about 500 miles on it.
Old Oct 1, 2014 | 05:54 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Any chance you still have this?
Old Oct 2, 2014 | 09:12 AM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Sold a while ago. Some local guy put it in a jet boat.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
sandman92084
Sep 12, 2015 10:27 PM
Strick1
Sep 4, 2015 07:11 AM
