[NJ] 350 hp 375 ft lbs dyno proven 350 F/S
Old Sep 30, 2011 | 12:29 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Basically right now the engine in my 86 is a 010 block assembled with an insanely overbuild bullet proof bottom end (ARP mainstuds w/stud gurdle, crank scraper + windage tray. Compcam (lost cam card but it sounds beastly)topped with a Holley 650dp (Fresh rebuild) (Arp mainstuds, crank scraper, m55 w/high pressure spring, 3927186 heads w/screw in studs + poly locks (Otherwise heads are untouched) . Arp Rod bolts(all internal hardware is arp), forged crank, rods, pistons, 10.1 comp ratio and low tension pistion rings (between the cam and rings a vaccum pump is required to keep the rings sealing properly). While it hauls serious **** I'd prefer to sell it and return the car stock as I plan to use it as a daily driver, I paid 1,800 for the engine and have put around 1,500 on it since, would like to sell it for 1,500 OBO (need a trans rebuild for my 86 vette) PM with offers, questions or anything else.
1992rs/ss
16
Jan 28, 2016 09:58 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
angel2794
Sep 8, 2015 06:22 PM
Eric-86sc
Aug 24, 2015 09:01 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
