[CA] 91 LB9 partout
Car: 1988 Pontiac trans am
91 LB9 partout
thought about going tpi , but right now its not the right time for me .
Here is what is available
- sepertine setup " all brackets , pulleys and tensioner " $ 80 plus shipping
- used power steering pump $25 plus shipping
- " new " MAP sensor $10
- used CTS sensor $5
- stock fan switch $5
- stock knock sensor $10
- new oil pressure sensor $ 15
- stock air intake sensor $5
- stock motor mount shells $ 25 plus shipping
- sand blasted exhaust manifolds with bolts and heat shields $ 50 plus shipping
- stock injectors $50 plus shipping " dont know if they work "
- stock intake base $ 50 plus shipping
- stock plenum $ 25 plus shipping
- stock runners $ 15 plus shipping dented !!!!!
- all stock intake related bolts $ 15 plus shipping
- stock distributor without cap $ 20 plus shipping
- stock valbe covers , one has a small dent $ 15 plus shipping
- stock EGR valve $5 plus shipping
- LB9 block with rotating ***. and pistons $ 150 LOCAL PICK UP ONLY !
- LB9 heads $ 150 plus shipping " includes all valvetrain .
ECM and HARNESS are not for sale , so please dont ask .
anything else i missed ? If so , shoot me a question .
BTW So Cal people , im located in riverside east of the 91 freeway " drive in area "
will post pictures up later .
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
Re: 91 LB9 partout
I am restoring a yellow 92 GTA and I am looking for the 14 mm bolt and metal clip that holds the alternator wiring. I believe that all 89-92 TPI cars came with these parts. There is no part numbers available for these parts so I am looking for good condition, rust free parts. Below is a picture for the bolt and clip. The clip should be golden in color and not bent.
I am also looking for 3 throttle body coolant clamps for 1991-92 TPI cars. I have tried buying them new but the 2 part numbers I have are for worm style clamps. I am looking for clamps in good condition that aren't rusty. Here are some pics:
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Re: 91 LB9 partout
I need the full snorkel intake if this is a camaro. Thanks
