[MD] LT1/T56 Combo No longer for sale
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Due to lack of time w/ 2 little ones, I'm shelving my skylark build and looking to buy a completed project (found another 3rd gen). To help fund the new car, I'm looking to sell the LT1/T56. I bought the LT1 from Scot (Samckitt) on Pro-Touring.com back in February. I haven't gotten it running yet due to not completing the fuel system but have videos of it running in his car.
1995 LT1 from Trans Am w/ factory aluminum heads, Lloyd Elliott cam (comparable to GM Hot Cam) w/ Comp 1.5 Roller Rockers & Beehive springs, Stock intake painted red & port matched to heads, 58mm TB, CSR electric water pump conversion, CV/Champ 8 qt road race pan, Aeromotive AFR, AN fitting welded to fuel rail, Corvette Composite fuel rail & Valve Covers, Woodward Racing remote P/S reservoir, Spearhead modified factory f-body harness (modified to fit Monte Carlo SS and fits GM A-body just as well, could easily be modded for 3rd gen or sell harness & get a stock F-body harness), custom tuned, MDS 6-AL.
2000 T-56 w/ earlier 93-97 input shaft & midplate, bellhousing. Brand new stock clutch & Pressure Plate, stock resurfaced flywheel, Brand new GM Hydraulic clutch assembly, 4th Gen F-body B&M Ripper shifter
I don’t want to separate but if I do, I will only sell engine separate as I can use the T-56 in new car. I was told the engine has about 30K on rebuild. Definitely was rebuilt as it has ARP head bolts. I did drop the oil pan & it is super clean. Trans has 30-40K miles on it but was gone through by local trans shop when input shaft/midplate conversion was done and no issues were found.
$2500 for the pair.
$2500 for the pair.
Want a title? Post!
Car: 91 Firebird Formula
Engine: 5.7 TPI
Transmission: 700R
Re: LT1/T56 Combo
Would you except $2000.00 for everything? I,m 9 hours away so I will probably need the rest for gas.
Engine: 5.7, 5.0
Re: LT1/T56 Combo
Sorry, decided to hold onto them for now. Price is firm though, have it on several other sites and have received an overwhelming response and already turned down a couple offers at my asking price. If I have a change of heart, I'll update this. Thanks.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
tonys91rs
Oct 10, 2015 03:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
