[NJ] SBC Roller Rocker Arm set!
Old Jan 15, 2012 | 08:45 PM
N.J.-SLICK-1's Avatar
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Axle/Gears: 3.73 limited slip
These are 1.5 ratio for 7/16th rocker studs Aluminum full roller rocker arms for the later self Aligning SBC heads w/poly locks, used but in excellent condition $125.00 plus shipping.
Old Jan 16, 2012 | 12:14 AM
swift141's Avatar
Want a title? Post!
Car: 1989 Camaro IROC Z28
Engine: L98 TPI Slightly Modified
Transmission: 700R4 B & M Shifter
Axle/Gears: 9 Bolt 2.7 LSD
Re: SBC Roller Rocker Arm set!
Will these fit under the centre bolt factory rocker covers. PM me your PayPal details.
What brand are they and how many miles ?
Old Jan 16, 2012 | 02:16 PM
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
I sent you a PM, and for anyone else with the same question, I have no idea if they fit under that type of valve cover since I have only had them under Moroso valve covers, and the mileage is below 2000 miles tops, limited street duty and weekend 1/4 mi. blasts.
Old Jan 18, 2012 | 08:06 AM
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Originally Posted by N.J.-SLICK-1
These are 1.5 ratio Aluminum full roller rocker arms for the later self Aligning SBC heads w/poly locks, used but in excellent condition $125.00 plus shipping.
bump
Old Jan 23, 2012 | 09:13 PM
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
bump!
Old Jan 29, 2012 | 08:07 AM
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
bump!
Old Feb 20, 2012 | 07:44 PM
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
BUMPITY
Old Feb 20, 2012 | 09:23 PM
Tony V's Avatar
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
What brand rockers are these?
Old Feb 22, 2012 | 10:29 AM
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
I think these are Proforms or Pro Products, but I'm not certain?
Old Feb 22, 2012 | 04:24 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
What size studs?
Maybe I missed it
Old Feb 23, 2012 | 10:27 AM
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Originally Posted by rawley2
What size studs?
Maybe I missed it
My apologies they are for the heavy duty 7/16th rocker studs not factory 3/8th studs, sorry for not including it within the description earlier..
Old Feb 23, 2012 | 10:48 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
How much work is it to swap to the 7/16" studs? And I'm guessing you haven't confirmed fit for center-bolt heads or not?
Old Feb 23, 2012 | 06:26 PM
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
I don't know what type of cylinder head you have, but the high performance versions and all aftermarket heads have rocker studs that just bolt in and can be upgraded with the 7/16th versions, but some of the lower performance heads come with pressed in studs that need to be pulled and tapped out and threaded for the screw in type rocker studs! Now on to the valve cover deal, I have no way of knowing that because I don't own that type of cover and I know it is short and has baffeling for PCV, air breathers, and oil fill caps, so I don't know if it will clear????
Old Feb 23, 2012 | 08:21 PM
lemons racer's Avatar
Car: 86 Camaro, IROC springs & bars
Engine: Mild 350,Q-jet,headers
Transmission: M-21, 12#flywheel
Axle/Gears: 98 7.5, 3.73 torsen.
N.J. I'll through this in just for info, those look like wide body rockers that won't fit center bolt valve covers. They do look like nice pieces though.
Old Feb 24, 2012 | 10:41 AM
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Thanks for your input, I really don't want someone to make a purchase on these and they won't work for their application, I had them under Tall Morosos, so thats all I can speak for!
Old Mar 3, 2012 | 04:27 PM
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Old Mar 7, 2012 | 10:18 AM
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Still Available!
Old Apr 26, 2012 | 10:56 PM
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Come and get them before the Englishtown Swap Meet!
Mickeyruder
Sep 2, 2015 02:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
