[KS] BMR torque arm, Rod end LCA's, springs
Old Jan 24, 2012 | 08:28 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
BMR tranny mounted torque arm $160 pending!
Custom lower control arms, rubber bushed ends on one side to control NVH (while still being much stiffer than stock), custom spacers, and 3/4" to 1/2" ID XMR QA1 rod ends with sealsit to keep the rod ends clean. I'm going to offset LCA's to go with my expande rear fenderwells. $120, you can't build them for this...
http://www.summitracing.com/parts/HAL-XMR8-12/
http://www.howeracing.com/p-7603-rub...ing-joint.aspx
1200lb/in 11x5.5 Hypercoil, $88 new, $50 ~1/4 coil cut from each, Nice and low on my car with an lt1. Guessing 2-3" drop. Still on the car, It will probably be a month+ before I get to changing them out, so just checking interest I suppose.
I ran these 8x5 springs with all star adjusters, just tack weld them to the axle and your good to go. http://pitstopusa.com/i-5066715-allstar-pe...juster-nut.html
250lb/in 8x5 Landrum springs $108 new, $60.
http://www.landrumspring.com/pages/coilspr...mp;pagenumber=1
300lb/in 8x5 Susp. spec. springs. $88 new, $50.
http://pitstopusa.com/c-134778-springs-rea...d-x-8-tall.html
150b/in 12x5/pigtail hypercoil $88 new, $50 ~2" Drop in rear spring with the stock isolators. Pretty low without...
http://pitstopusa.com/i-5069261-hypercoils...-appearing.html
I also have front IROC springs, the 707lb/in 5664 p/n. I think I took off 1/4 or a 1/3 of a coil, just enough for some slight lowering. $40
All prices plus shipping and handling. I take paypal. Email me at (my screen name here)@gmail.com or call/text at 785-230-9516
Old Jan 24, 2012 | 08:49 PM
1988TransAm22s's Avatar
Car: 1988 TRANS AM procharged
Engine: 305 procharged TPI with 5 speed
Transmission: 5 speed
Axle/Gears: 3:73
Re: BMR torque arm, Rod end LCA's, springs
really wish i had money in paypal i would snag upt he torque arm in a second. to the top
Old Jan 26, 2012 | 07:36 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Shiped
Old Jan 26, 2012 | 07:42 PM
gp90gta's Avatar
Car: 1990 GTA
Still have the torque arm?
Old Jan 26, 2012 | 07:49 PM
Roostmeyer's Avatar
Axle/Gears: 3.70
I'm guessing shipping and Paypal fees will be about $25. If someone's interested I'll pull it tonight.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
