parting out 1987 z28--5.0tpi car
Want a title? Post!
Engine: 427 sbc
Transmission: t400
Axle/Gears: moser 12 bolt
Re: parting out 1987 z28--5.0tpi car
Just saw you have two cars for parts. On the tpi car I could use the bracket that the dual fans attach to at the bottom, mounts to the bottom of the rad support tray. price shipped to 08344, along with part on other post. thanks
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
Want a title? Post!
Engine: 427 sbc
Transmission: t400
ok i will take it. pm me paypal info check other post only need the cover for the heat box if you have it i will take both
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Looking for the wiper motor, mounting bolts and the screws that connect wiper linkage.
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Is the upper radiator support bracket available? I could also use the fan plugs going into the dual fans. My zip is 78249 (if you have a picture that would be great)
i think i have the part you need??? is this it??
I am looking for that part on top that the dual fans bolt to, as you can see mine is all cracked to hell.
Transmission: 5-speed/T-5
ECM, and possibly the harness, shipped to N3R 4V5?
1992 Trans Am
May 10, 2023 07:19 PM
beachrodder
Aug 25, 2015 08:05 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
