newly built 355 short block
Old Feb 6, 2012 | 08:45 PM
Project-RS's Avatar
im selling my newly built 355 short block. its fully assembled and ready for heads/intake. everything is brand new except crank, rods, pistons. parts include:
comp cam magnum camshaft/ lifters: http://www.summitracing.com/parts/CCA-CL12-211-2/
piston rings: http://www.summitracing.com/parts/SLP-R9903030/
timing chain: http://www.summitracing.com/parts/SUM-G6600/
oil pan: http://www.summitracing.com/parts/SUM-G3500X/
timing chain cover: http://www.summitracing.com/parts/SUM-G3200/
melling high volume oil pump with melling accesories.
main bearings : http://www.summitracing.com/parts/CLE-MS909H20/
camshaft bearings: http://www.summitracing.com/parts/CLE-SH290S/
rod bearings: http://www.summitracing.com/parts/CLE-CB663HN20/. im sure i left something out, but feel free to ask. looking for 600 plus shipping. i can get pics of the build
Old Feb 6, 2012 | 08:49 PM
Project-RS's Avatar
Re: newly built 355 short block
Old Feb 7, 2012 | 07:48 AM
galletti's Avatar
Car: 1988 IROC Convertible
What's the casting number on the block? How much are you asking?
Old Feb 7, 2012 | 07:54 AM
Project-RS's Avatar
ill get the casting when i go to the garage. it a 1979 350
Old Feb 8, 2012 | 08:25 AM
88WS-6's Avatar
Car: 87 IROC
Engine: LB9
Axle/Gears: 3.70 9 bolt
2 bolt main, 1 piece rear main seal? How many miles on the crank, rods and pistons?
~Matt
Old Feb 11, 2012 | 05:22 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Looking at the pics the seller has posted shows it is a 4 bolt main block. He also said it is a 1979 350. which everyone knows that chevy did not have a 1 piece rear main seal motor back then. Hope this helps with the sell of the short block for you Project.
Old Feb 11, 2012 | 05:27 PM
Project-RS's Avatar
it was taken apart. only parts i have left are the cam, oil pan, timing cover, pistons (no rings)
Reddeath210
Oct 6, 2015 08:20 AM
Ducati900ss
Sep 2, 2015 09:05 AM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
BBSDesigns
Aug 11, 2015 07:39 PM
