[CA] 82 clutch z bar
Old Mar 1, 2012 | 10:21 AM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
82 clutch z bar
i have an extra clutch z bar with pivot and frame bracket. its in good shape. 55 shipped in the us. thanks
Old Mar 2, 2012 | 08:20 PM
svrider76's Avatar
Car: '83 TA DT500 HT
Engine: LG4
Axle/Gears: G80, 373
Re: 82 clutch z bar
Do you have any Pictures?
Old Mar 2, 2012 | 11:29 PM
Re: 82 clutch z bar
here ya go
File Type: zip
File Type: zip
Old Mar 2, 2012 | 11:33 PM
Re: 82 clutch z bar
not sure if that worked?
Old Mar 3, 2012 | 10:41 AM
svrider76's Avatar
Engine: LG4
Re: 82 clutch z bar
The first picture looks like it might have a crack at the weld? How is the integrity of the bar?
Old Mar 3, 2012 | 10:46 AM
Re: 82 clutch z bar
its just the photo from my ipod. the bar is solid. iv had it as a spare for years, now im pulling my t10 out. i have all swap parts too. if you need anything else? thanks
Old Mar 4, 2012 | 09:57 AM
Re: 82 clutch z bar
Bump
Old Mar 4, 2012 | 08:47 PM
svrider76's Avatar
Engine: LG4
Re: 82 clutch z bar
Will this work with the 83 T5 trans?
Old Mar 5, 2012 | 12:52 AM
Re: 82 clutch z bar
not sure if they are the same or not? i think the difference between the t10 and t5 were the bell housing bolt pattern, not the linkage?
Old Mar 5, 2012 | 03:47 AM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
Re: 82 clutch z bar
82 was the only year for the mechanical clutch linkage.
Old Mar 5, 2012 | 08:42 AM
buffaloman's Avatar
Car: 1989 Firebird Fornula 350
Engine: 350 L98 / NOS
Transmission: 4sp Auto
Re: 82 clutch z bar
1982 and 1983 had the Z Bar. 1984 went to Hyd.
That bar will work for eighter year.
Old Mar 5, 2012 | 02:02 PM
72vega's Avatar
Re: 82 clutch z bar
i stand corrected. i didnt know the t5 also had said mechanical clutch
Old Mar 8, 2012 | 10:05 AM
Re: 82 clutch z bar
bump
Old Jan 16, 2015 | 11:59 AM
lexpaintitblack's Avatar
Car: 83' Z28
Engine: 5.0 V8 305
Transmission: 5 SPEED
Axle/Gears: Stock
Re: 82 clutch z bar
I know this is old, do you still have the z-bar?
Old Jun 27, 2017 | 12:14 AM
Re: 82 clutch z bar
Super delayed response..... ha. But yes I still have it
Old Aug 13, 2017 | 01:52 PM
fteufert's Avatar
Car: 1982 T/A
Engine: 1973 400 Chevy
Transmission: 4 Speed Borg Warner
Axle/Gears: 3:23
Re: 82 clutch z bar
If it is still available, I will take it for $55
Old Apr 18, 2018 | 12:26 AM
Re: 82 clutch z bar
Back from the dead. The zbar is still available. Thanks
Old Apr 20, 2018 | 12:33 PM
Re: 82 clutch z bar
Took 6 years.....but it’s SOLD! Thanks Fred
Old Jul 21, 2020 | 09:30 PM
Harrisbueler's Avatar
Re: 82 clutch z bar
Resurrection of the thread lol. Any chance you have any of the t10 swap parts? If not lets let the thread die 😂
Old Jul 24, 2020 | 07:28 AM
Re: 82 clutch z bar
Sorry man, it’s all long gone
Old Apr 24, 2021 | 08:12 PM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Re: 82 clutch z bar
I like this thread, cause it has photos of the Z-bar. Good to still have this info. I myself prefer this method of clutch release over the hyd., because of the simplicity, which means reliability. This set-up was used since Christ was a corporal, and is proven. Of course the components have to be correctly aligned, lubed, and installed, but will give years of dependable service. We all know how difficult it is to find this rare set-up, so naturally people will talk down at it, and build up the new hyd. systems, mainly cause they're easily available. But I just assume keep away from an extra reservoir on my firewall, next to the master cylinder, along with another cylinder inside the bellhousing, which have the potential for leaky seals.
As for the transmission question, these mechanical, or hyd. release methods have nothing to do with the transmission. It is mounted before, and in the bellhousing, and doesn't know or care what tranny is installed behind it.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
