[Sold] Running LT1 engine for thirdgen swap
Old May 17, 2012 | 07:53 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Engine is currently in my 87 Firebird. Hear it run before purchase. Came from '95 Trans Am. Aluminum heads, 5.7L. Starts easy, idles smooth, doesn't use oil. This is not a "it-ran-fine-a-couple-years-ago" mystery motor. T56 6-speed trans and other aftermarket components available for additional price.
Engine oil pan to intake
Air intake
All belt driven accessories included
Manual trans wire harness and PCM adapted to thirdgen chassis
All sensors including MAF
Plugs and wires
Manual trans flywheel
Fuel pump relay
VATS module
$1150 local pick-up only
Old May 22, 2012 | 05:59 PM
deadlyshot99's Avatar
Want a title? Post!
Re: Running LT1 engine for thirdgen swap
How much for t56 swap?
Old May 22, 2012 | 08:47 PM
ACCLR8N's Avatar
$1800 for T56 Trans, Spohn cross member, Spohn adj torque arm, B&M shifter, tunnel boot, pedal assembly, clutch hydraulic assembly, polyurethane mount. No clutch. Shifts smooth no noises.
Old May 25, 2012 | 06:51 AM
bcashJMU's Avatar
Car: 1991 Trans Am GTA
Engine: 1987 350 TPI with mods
Transmission: 700R4 (shift kit)
How much for both complete engine and transmission?
Old May 25, 2012 | 08:41 AM
ACCLR8N's Avatar
I have a deposit on the long block and intake to repair a 95 Camaro. Balance of swap components available.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
