complete tpi setup + 65# injectors + complete harness and megasquirt 2 v3.0 ems
Old May 17, 2012 | 07:11 PM
project89's Avatar
looking to trade my fuel injection setup for a complete blow threw carb setup
carb
intake and carb hat
tpi base has been modified to fit both perimiter style and center bolt heads
u get complete tpi setup
brand new
precision 65# low-z injectors
megasquirt 2 loaded with ms 2 extra 3.2.1 code which is the latest
wiring harness to wire up the megasquirt ( no cutting or splicing needed , just mount the ms in place of stock ecm run the harness out to the motor plug in sensors hook up 2 gounds and one keyed power to the ecm
edit
pictures added see below
Old May 17, 2012 | 08:20 PM
project89's Avatar
Re: complete tpi setup + 65# injectors + complete harness and megasquirt 2 v3.0 ems
will also sell outright for the right price
megasquirt 2 v 3.0 costs 437$ new
unterminated harness is 80$ new
avg price of complete tpi is about 300 bucks
precision turbo 65# injectors 505$ brand new
so the whole package would cost 1322.00
will sell whole package for 800.00
may split up if i can find buyers for everything
Old May 17, 2012 | 10:01 PM
project89's Avatar
pictures
tpi
and for thos eof u that dont know what a megasquirt ecm looks like
Old May 18, 2012 | 06:53 AM
BLK MAJK's Avatar
Want a title? Post!
Car: 97 GMC Sonoma
Engine: 383
Axle/Gears: GM 8.5 with 4.10s
might be interested in the megasquirt and maybe the harness...(going in a Sonoma, so depending on what was done to the harness)
Old May 18, 2012 | 04:18 PM
project89's Avatar
the megasquirt harness will connect the ecm to the engine
it has all the wiring for the injectors,distributor, coolant temp air temp tps and aic, it also has a fuel pump relay wire for turning on the fuel pump but i have that wire seperate out of the harness since my fuelpump is wired to a toggle switch along with my main power wire. but i can put the fuel pump wire back into the harness for u if u like
if u go this route u would need to wire up ur fans seperatly since i dont have the ecm setup to control the fans, but its very easy to do using the stock fan switch
i can also setup the ecm to control the fans on the fidle wire for u as well
Old May 23, 2012 | 04:45 AM
twest2k2's Avatar
Car: 87 Camaro IROC-Z 5.7 TPI
Engine: 350 aka 5.7L Tuned Port Injection
Transmission: 700-R4
Axle/Gears: 3.27 posi
How much for the megasquirt and harness?
Last edited by twest2k2; May 23, 2012 at 10:55 PM. Reason: found answer to first question
Terrell351
Jun 13, 2021 01:13 PM
Caspar
Jun 19, 2016 11:19 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
squiggy2
Aug 9, 2015 09:30 PM
