completely disassembled 305 tpi 51,280 miles
Car: 1986 camaro iroc-z28
Hello, ok so I pulled my 305 tpi engine out of my 1986 iroc z-28 with 51,280 miles the number 5 rod bearing started making noise so I had a 350 built and am not keeping anything from the 305 except the block. If it's ok to do it this way,cool. Let me know what you need and I'll let you know how much and if it's available. I am located in Pa 15322 zip, but can try to figure shipping if needed. Thank you.
Re: completely disassembled 305 tpi 51,280 miles
no one needs any parts? have a lot. heads,rods, push rods, pistons, oil pump, oil pan, tpi system, ect.... thank you.
Car: 1992 Pontiac Firebird Formula WS6
Axle/Gears: 3.23 L-Slip w/ discs
I would love to get my hands on those heads, but it'd probably cost an arm and a leg to ship 'em up to me lol.
Car: 88 Sport Coupe
Engine: 383
How much for the oil pan shipped to 60922? And I have a noob question, it should fit my GEN I small block right?
Car: 1989 Formula
Oh, and the oil pans are different depending on if you have a 1 piece or 2 piece rear main seal BTW...
Car: 1989 Formula
No problem, not in a huge hurry, and no problem on the valve seals. They'll get some port work and a 3 angle valve job anyway.
Car: 1989 Formula
Actually cancel that anyway, just re-read that yours is a 86, I want the 87+ heads anyway. Thanks though...
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
Is your oil pan for a 1 pc or 2 pc RMS? I need a good condition one for a 1 pc, my block is 87 or 88. If it is for a 1 pc RMS, how much shipped to 90248 and do you have a picture?
sorry it took a couple days to respond,(I'm not getting notification when someone responds) I can take a picture, it is for a 1 piece.
Yes the solenoid. It looks like it mounts on the same bracket as the coil. I'm needing that bracket also if you have it. And of course the Diverter valve that is coming off of the smog pump. Thanks...Gerald
Do you have a tpi car? I ask because my coil is on top of my distributor I have a HEI distributor.
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
oil filter adapter, serpentine setup, and motor mounts?
I'm in the process of building my first one, so I'm buying a few parts at a time to get it together. I could consider the HEI unit if the price is right though...
Want a title? Post!
Car: 1984 Z28
Engine: L69 H.O.
Transmission: T5 hoping for a T56 in the spring.
How much for full tpi system shipped to 22911? Thanks
here is a picture of it when i took my exhaust off one of the bolts came out. I know that no biggie but I wanted to tell you. in case you cant see it.
Car: 85 Z28 Camaro 2011 camaro LS
Engine: 350 Edelbrock Crate bored .60 over
Transmission: 400 turbo
how much for the tpi system with harness and computer shipped to 33312
Sanjay
Aug 12, 2015 03:41 PM
