[AZ] 305 TBI Long Block w/LT1 Cam, World Class T-5
Car: A Camaro
Engine: Weak
Transmission: Weaker
Hey everyone,
I have:
Long block from my car (92 RS) that is stock except for an LT1 cam, Z28 springs, double roller timing chain, and new new valve seals. Ran great when I pulled it, maybe 105 - 120,000 miles on it? Made 216 rwhp, 266 rwtq. Only issue is that there is a bolt sheared off in the rear of the driver's side head for the exhaust manifold (was like that when I bought it, the manifolds/headers never leaked though) - $100 OBO
Stock World Class T-5, bellhousing, clutch, flywheel and shifter. Worked fine for just driving around the street, but when it heated up it had some difficulty shifting into 3rd and 5th. Probably could use a rebuild to be honest, but your call obviously. $300 OBO
I don't check the boards much so PMing probably wont' be checked for quite some time.
Thanks,
Tony
I have:
Thanks,
Tony
Car: 1989 Camaro IROC-Z Convt.
Engine: 355
Axle/Gears: Zexel Torsen 3.42
Re: 305 TBI Long Block w/LT1 Cam, World Class T-5
Do you have a T5 exhaust hanger for the catalytic converter?
Car: A Camaro
Engine: Weak
BlackphantomZ28
Apr 24, 2016 08:14 AM
